SDS100/SDS200: DMR Slow Scanning?
AngWay
GRUNDY
I have the SDS100 and i have searched online and found few things about the sds100 and DMR scanning being slow for some reason i am having this issue but i can't figure out what could be wrong. my scanner will scan fine and when it comes upon a DMR single freqs it will hang there for a long time and flash color code and DMR does anyone know what causes this and if it's normal is anyone else having this problem? This Video is what i'm talking about it will hang and there is just silence no traffic at all.
dave3825
Suffolk County NY
Flashing color codes, nac, pl tone, ran etc indicates the channel is programmed to search for a tone. If you program the tone it does not flash.
Whiskey3JMC
Just another lowly hobbyist
Philly burbs 🇺🇸
My guess based on the video is TG-0 on slot 2 is likely broadcasting data of some sort (maybe LRRP or the like?) DSDPlus would tell you for sure. There might not be any voice traffic carried on slot 2 at all. Program the frequency as one-frequency trunk and program the talkgroup you can confirm voice activity on & set TDMA slot to slot 1 only.
According to the video the tone is programmed in (CC6)
AngWay
GRUNDY
My guess based on the video is TG-0 on slot 2 is likely broadcasting data of some sort (maybe LRRP or the like?) There might not be any voice traffic carried on slot 2. Program the frequency as one-frequency trunk and only enable the talkgroup you can confirm voice activity on & set TDMA slot to slot 1 only.
Ok with the slots it's going from slot 1 to slot 2 so i need to figure out which slot has the voice and which has no voice and set it to the one that has the voice? because what i have been doing is setting it to any and leaving it at that.
it's showing both slots and i'm getting no audio from either. but i am hearing audio on dsdplus same freqs
AngWay
GRUNDY
I know what the tone is and i have it programmed. i also have it set to blink when the channels are active
AngWay
GRUNDY
I have this Video that shows files from dsdplus in universal player that it's playing that freqs. if there is another file or log tell me and i'll upload it. the talkgroup in that is 2500 and 3500 i think
dave3825
Suffolk County NY
Read what you wrote. Said it flashes color code. Not something you can program it to do. If it’s flashing it’s because it was found with audio option set to search.
AngWay
GRUNDY
No i was talking about the alert light i have it set to flash. the color code is set to search
AngWay
GRUNDY
But umm the last screenshot in your post here shows encrypted traffic from 155.700 TGID-1 on Slot-1...
if u look closely u can see that was a different freqs i switched to the 155.7000 to show it was saying DMR.
again the freq before that was 154.37
