Erie County P25 System
maus92
OCMD
My location is just west of W.38th and Buckthorn. I tried using just the County site and avoiding the Urban site. I got no signal at all with the County and no reception. The Urban site shows 4 or 5 bars, and I hear most TG's. Overall reception with both sites active seems to vary some from day to day. My 536's on the 2nd floor sound ok, but the one on the first floor has me adjusting the telescoping antenna a lot. I have it extended all the way now and it helps some. Still considering an SDS200, but all the problems are scaring me away (loud hum, dispaly issues, etc.)
BTW, when you extend the antenna on the downstairs radio, you are actually detuning its electrical length wrt the UHF band. That is probably helping to attenuate signal received from further away sites.
maus92
OCMD
I fail to understand your thinking. 436 with a duck or whip is deaf on the rural site. With a good antenna it works fine.
I'm not talking about the Countywide site. I'm talking about being well within the Urban Cell where sf is clearly experiencing C4FM or CQPSK (I think EFJ uses C4FM) multipath.
scnrfrq
Erie, PA
I thought you plotted from the FCC data? Check the DPS Flower RD radiation direction. Fairview VFD is also a Rural site as is Hamot.;
What is the final chart then? Do we have one that shows which towers are urban and which are county?
maus92
OCMD
I gave you a chart relevant to the discussion wrt SF's issues. The mapping I did was based on the last county logical design that I saw, and informed by FCC licensing data that I added. Note that all Cell A (Urban Simulcast) sites are LICENSED for all frequencies used by the system including frequencies used by Cell B (Countywide Simulcast) - except for Presque Is. which only uses Cell A freqs. That means that Cell A is technically an overlay network. Whether it actually functions in that way is another matter, and I don't think it does based on what people have reported. At any rate, it doesn't matter. SF says he cannot receive Cell B (Countywide) at all from his location, which suggests the system is not transmitting Countywide channels from Cell A (Urban) tower sites - even though they are licensed to do so. It doesn't change anything I stated about his reception or the solutions I recommended. What would be *nice* is if someone on the ground in Erie would *visit* the Cell A sites with a frequency counter / Close Call radio, and determine if the Cell A sites are also transmitting on the Countywide freqs.
scnrfrq
Erie, PA
I'm testing my scanners on the 2nd floor to see if I get any reception on County alone.
scnrfrq
Erie, PA
So, it appears I'm not receiving the County site on any of my scanners. I seem to be getting all channels county-wide on the Urban site, but possibly not the County TAC channels. Not sure about that.
This is news to me after all this time. I assumed I was getting all TG's from both sites. I'll continue to test and see if I do get County TAC channels on the Urban site.
Railbender
NW PA
You will not get the Rural TAC talk groups on the Urban site.
I went for a ride in the rain this morning while monitoring the Rural site in analyze mode. Found a spot with very poor Rural reception, even my G3 was fluctuating between 3 and 4 of 4 bars, but still receiving fine. The Asbury woods nature center parking lot on the east side of Asbury road. My 436 with the duck was deaf, my HP2 being feed by a Tram 1185 2m/70cm antenna was showing only 20% signal strength. Going south on Asbury from 26th I watched the signal decrease rapidly. If you look at the FCC license for each tower and plot the radiation pattern (azimuth and beamwidth) from the information on the license you will see why.
Railbender
NW PA
  • Erie County FCC licensed freq review per site rev L(911).pdf
maus92
OCMD
County getting these to fill in communications gaps...portable sites.
Are those to be used on an interim basis while awaiting construction of permanent sites?
Railbender
NW PA
Yes. They were working on the North East tower yesterday. There was supposed to be a tower on the North East campus of Mercyhurst University, but they closed that campus and the property is for sale. Don't know if the transmitter was ever on the air. I havn't been out there since last fall.
TV report on system issues. Attached is a report from John Grappy.
scnrfrq
Erie, PA
Been hearing TG 125 fairly often, but can't tell what it's used for. Anyone else hearing it?
Railbender
NW PA
What radios are you seeing used with TG125? The one hit this morning was with radio 8200000, which is associated with west county fire.
scnrfrq
Erie, PA
Not sure if the SDS200 or 536 shows which radio is transmitting? West County makes sense, since that TG is close to the ones they use.
Railbender
NW PA
I got that info from PRO96Com. I already had it programmed so it has been around for awhile. It is probably an interop. Both the SDS200 & X36 will show the radio as Unit ID (UID).
scnrfrq
Erie, PA
