Owned a mix of approx. 10 scanners over my lifetime - even back in the day when you had to punch everything in manually.... NOW, have a BCD436HP that I am trying to get an NXDN trunk on
https://www.radioreference.com/apps/db/?sid=8654
and it will not happen no matter what I try. Yes, I HAVE the NXDN upgrade along with the current scanner firmware - even followed a step posting that supposedly works - but nothing happens - will not show up while scanning or in any 'mode'. The radio does work perfectly otherwise.
On the premise I am a total idiot, could anyone post ( starting just after you turn the radio on ) an exact step by step mode of getting this NXDN trunk up and running. WOULD BE MUCH APPRICATED!!
Leave it to Uniden to not only charge for the NXDN upgrade - but then find out that Sentinel does not handle NXDN as of yet! Perhaps if you have the upgrade ava., then Sentinel should be able to deal with it..........
