kf8yk
Using Unitrunker I'm not seeing anything as a peer for the TOW.
TOW's are standalone trunking systems & are not interfaced to a zone controller. They will not appear as a neighbor on a regular MARCS site & the TOW's don't broadcast any neighbors.
Jphila20
Retired LE. Honor our Fallen.
Southern Lorain County, Ohio
I plugged in all the CC's listed for the two TOW's in RRDB with no signal this afternoon.
wa8pyr
Lead Database Admin
Ohio
I monitor MARCS and I'm in southern Lorain County. Using Unitrunker I'm not seeing anything as a peer for the TOW. I see 02-022 with no name or hits. I plugged in all the CC for the two TOW's in RRDB with no signal.
The TOW trailers are stand-alone, short range sites that can be taken anywhere in the state on an as-needed basis. They have no peer sites, and unless you're pretty close, it's unlikely you'll hear the TOW site itself unless it's on a very tall hill.
fred4544
Akron
Subject: General Inquiry
Message: regarding the CVSR, I have a radio scanner that picks up regular rail channels and the Ohio marcs system. I’ve heard the communications on both (62735 TG and AAR57), except the brake test in Akron. Are they using a 2nd marcs talk group for that. I can’t pickup , or another regular RR channel or cell phones ? Also , they talk about channel 16, Thanks so much in advance for your answer . Fred Wheele - please text if possible
85chevy4x4
Cuyahoga Valley Scenic Railroad
N8WCP
wd8chl
They don't usually tie those in to the rest of the system, so there would not be any peers or adjacents. But they also could have taken it down by now. That was a few months ago.
wd8chl
Meanwhile, I can verify visually that the tower for the new site in Sheffield has been constructed. Can't miss it. Just west of SR301 (Abbe Rd) and just south of SR611 (Colorado Ave). When I went by last week, it looked like they might still be hanging antennas, but I'm sure that would be done by now.
There's a water treatment plant back away from the roads, and it's behind that.
fred4544
Akron
Negative, it's Summit County P25 T/A.
regarding CVSR communications:
When a blogger says they are getting both TG 52735 and TG 52737 in Cuyahoga County . but I have only hear TG 52735 from Akron. Could this be why i am missing the other radio talk from the train , (just between the engineer and conductor, regarding the brake tests and departure orders).
Is there a difference from which county I upload the Ohio-MARCS-IP system on my scanner? There has to be a difference, because if I am listening to the entire Ohio-MARCS-IP system, I would receive from Dayton, Columbus , and others further away. Its Probably that I do not understand it very well. Please help me figure this out. I appreciated the help ! Thanks ! Fred
amcferrin90
Pickerington, OH
This is possible if there's not a radio on the 52737 TG in Akron when you're listening. The system doesn't transmit TG's that don't have a radio tuned to it on every tower. It saves the system from being busy broadcasting to nobody.
If you were in range of one of the other sites you could put your scanner on site hold and switch to those sites.
wa8pyr
Lead Database Admin
Ohio
And this is completely logical for the CVSR, since they usually do their brake tests up north before the trips leave.
iceman977th
Catlettsburg, KY
any idea when this site should go online? i heard they needed the power ran to it but that was almost 2 months ago
Looks like it's active now. 03-84, primary 859.4625, secondary 858.0375. Submitting for entry to the DB now. Also including a screenshot in case there's something missing.
I'm working on getting Calls nodes for the Scioto Co sites today, been tweaking my SDRTrunk ingest. It'll be moving to a different tower site with less RF soon.
