New Streaming, Logging and Recording Software
cengleman
Kingwood, Texas
Can't wait.. bought RadioLog for my main PC...but now need to move it to a virtual recording server and without being able to contact the licensing server I am dead in the water.
Chris
KD7DDC
Salt Lake City, Utah
So some good news and some bad news.
As everyone knows Joe shutdown his site and stopped production of his software.
However we made a version of the source code available, I was able to compile the source into a working program.
So good news is that I was able to get the program running on a PC that never had it before.
The bad news is that something in the code or my setup is not correct and causing an error.
The code is not the same as the version I purchased, there are some minor changes. For example the Motorola Turbo option is not there. So I don't know how much this version was tested and if it is a 100% working code.
The first time I tried to compile the source, the program would crash because I was missing a file. After I fixed that issue, the program does run and work.
So at this point I am trouble shooting the code/my configuration and trying to find the source of the issues. What I was able to figure out today is that the log file fills up and once full the program crashes.
The message in the log, if anyone has an idea what it means, I haven't figured it out yet.
[Gray] - Sound Sample Byte: 0 = False
So far I have had the software running since the last post without crashing.
The software seems to be in verbose logging mode. I was able to comment out the lines of code that was causing the most issues for me. Seemed like it was logging every bite of audio. .
It would fill the hard drive and crash.
With those lines of code removed now it is just logging standard stuff and MDC id's. Going to remove these lines also as the MDC ids get logged into another file.
The log is set to a 50mb limit but it's check only when the program starts. Once running the log was running away.
Now after a few days the log is just under 1mb.
Think with removing the extra logging, we should be good to go.
The next step after this is to figure out the licensing to make sure I can release it. Joe left some instructions, now have make sure I understand it all properly.
Final thoughts.
The basic functions of the program are working with the exception of the ability to use a turbo radio as a modem.
Any updates? What is the possibility of making this open source and freeware/shareware instead of some licensing system? My main use is for running multiple feeds at one time, and the recording features.
dispatchgeek
Control channel goes "brrrrr"
Between the cornfields and the pastures, Michigan.
I can't wait to see what you come up with as well. I had intended to buy this program to run Multiple scanners in on different sound cards along with the online streams I monitor. Sadly, he had closed up shop when I was ready to get setup. I will be waiting.
nick223
Ottawa Illinois
I have notice trying to add a feed with RR the database doesn't populate all the way but on my other computer with radio log it does.
I also tried adding feeds to the iOS app and the app just closes out
cengleman
Kingwood, Texas
Has anyone ran into issues recording over 10 feeds/line in connections?
I plan to split all my radio feeds to the speakers and to the software once I am able to move it to another computer.
Chris
Dgoodrow
RadioLog, is there a download available.
Is there a download available ? I would like to try this software for logging MDC1200 PTT ID.
stevecast2024
I saw a few people talking about this being brought back to life. Has anyone found a download, or is there an old copy of the setup files somewhere? I imagine it would be no good without the ability to register. Has anyone had any luck getting the source files up and running?
ottomatic
Bumping this. Any further word on whether this will be coming back in any usable form?
stevecast2024
No updates on a replacement to this? I would be willing to pay decent money for this or something similar if it is available.
KD7DDC
Is anyone having trouble with this starting today? Mine will no longer connect to any feeds. I'm worried that the software is now unusable
sfd119
Hope not. The computer I run this on hasn't been shut down in over two years now. I fear for the day it goes down and I have to start the software up again.
Citywide173
Attleboro, MA
I just loaded it and it won't connect. There should be a refund option for something that went unsupported so quickly.
Livewire3286
Montesano, Wa
Gosh I sure hope the program is restarting when it needs to. I have the hard drive that mine runs on cloned just in case it ever went down, This program had become essential in some of the things that I do. Yes, I too would be willing to pay for something that at least did recording of multiple feeds local and online. I am not into the mdt tracking and all that I have dispatch CAD access for that :) .
sfd119
tbendick, I know you are active on the Forums here. PLEASE just tell us if you have something working, not working, or whatever. Have you abandoned this or is all this a bamboozle?
I use the MDC Roll Call, Maydays, etc on the fireground and I'd like to keep using it but if this program is dead I'll have to migrate to something else instead of holding my breath on your words of "working program".
rpfd41
Port St Lucie, FL
I also have used this program for sometime and need to change over to another computer is their anyplace I can find a download copy of the program all I really need is the Radio ID with Maday that you can Alias the units. The Playback was a big perk but the overall look and large screen display is really all I need. All the other interfaces just don't match up and you can't Alias the units. Any help on a copy of a download is Grateful..
Like sfd119 stated
Citywide173
Attleboro, MA
I noticed that the web sites listed in the first page is giving a 404 error.
Has this project died?
If you had read the entire thread, you would have your answer....kind of. Original project is dead, although there may be some life in it from a third party, but that third party has been pretty quiet about any progress lately.
vabiro
Toronto, Ontario
Thanks for the reply. Sorry, I checked the most recent posts (< 1mo old) and that wasn't clear.
