ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
n2pqq
Is there anyway to make the text larger within the program ?
Is there anyway to adjust font sizes ?
I have a 24 inch wide screen monitor and text is small.
ProScan
Software Provider
Ontario, Calif.
It can't be done within ProScan or any other Windows Program with a lot of controls. I've looked at this before a few times. Resizing the text will make the program not look right as the controls and options will be cut-off and not fit. It's a windows thing. If you know of a Win program with lots of controls that auto sizes nicely, let me know and I'll revisit it.
On Win 10 machines, this link will show how change the size of apps. https://www.windowscentral.com/how-make-text-apps-bigger-windows-10
Natrona Heights, Pennsylvania
You could try to use the Magnifier from Windows. It works for me!!!
I have been having a problem playing back recordings. I am getting a 1 second record and a another one with zero time recorded . The 1 second one usually gives the TG and the zero doesn't. If you play the two recordings back , you miss approximately a second between both recordings but it is one transmission. It seems to happen when a TG 's Digits are extra long like 16777215.
Thanks,
Brian
iMONITOR
Silent Key
S.E. Michigan
If you a dedicated computer for ProScan, or just a second monitor, you can lower the entire screen resolution, which will make everything much larger. This perfect if viewing from any distance. You can even make it big enough to be viewed across the room!
freqseeker
Puget Sound WA.
Updating multiple instances on one computer.
I am running three radios using ProScan on one computer. Works great, but I have a question about how to install updates to the additional two instances. Do I delete everything in the additional folders and copy the original every time? If so will it keep the previous settings for that folder? I read the manual and believe that is the case.
I am using windows 10 if that matters. I had luck just updating the application file in the past, but the last time I received .dll errors.
Thanks.
ProScan
Software Provider
Ontario, Calif.
Thanks.
Just copy the ProScan.exe, all dll files, & ProScan_Manual.pdf files to a new folder
If you want the same options then copy ProScan.cfg file to the new folder.
freqseeker
Puget Sound WA.
Thanks for the fast response. I assume the ProScan.exe file is listed as application in the file manager.
The reason I ask is the the CONFIG file ProScan.exe is what I assume you call the .cfg file.
Thanks again, great program and support. Just clarifying the above is correct.
Vince.
ProScan
Software Provider
Ontario, Calif.
Vince.
Copy the circled files
dave3825
Suffolk County NY
BCasto
Morrisville NC
Bob, I just installed Pro96Com to decode P25 sites. The data provided by that app is pretty cool. Just as an out of the box idea, could you and the Pro96Com author put your heads together and combine functionality. I truly like your Proscan app and am amazed at what it can do. I ran the Pro96Com on a Windows system attached (front port) to my Uniden XT scanner built with Proscan. I can't run them both at the same time though. Not sure of the scale of effort, but a combined set of functions would likely broaden your market and increase users value. Right now Pro96Com only does P25. Adding other systems would be gigantic and could put you in the space to get some of the casual SDR DSD+ business for users just doing decoding. Just a couple thoughts offered with sincerity to a respected app provided.. :)
ProScan
Software Provider
Ontario, Calif.
Bob, I have a few Cap + freqs entered into my 436 and I see that while Proscan does display site info, it does not log what it sees. I entered the freqs and put a space in front followed by MHZ as seen in bravo14's video here https://forums.radioreference.com/u...134-analyze-lcn-finder-again.html#post2810355
My video of Proscan seeing but not logging here. https://www.youtube.com/watch?v=IjjjmflWYzE It is set to log each entry in a new row.
I'll look at this soon. What's the firmware version?
dave3825
Suffolk County NY
1.11.31 is what the scanner is running.. The site info does show on the scanner also, not just in Proscan. If you need anything, let me know.
pbeezy
536HP RSOIP issues with audio and connectivity
I've had a server running on and off for a year or so. Clients get disconnected Server Code 8 usually about 10 minutes in. I haven't had this issue before.
Additionally I can only use G729 as my codec, Mp3 is choppy at any bitrate/sample rate. I am connected via Wifi dongle.
I don't have the Mp3 audio issues on my Webserver or Icecast stream. Any insights?
ProScan
Software Provider
Ontario, Calif.
Why not? Connect Pro96Com to the front or rear port and ProScan to the port not used by Pro96Com. That way both programs will work on same scanner.
ProScan
Software Provider
Ontario, Calif.
When did this issue start? Are all the clients disconnecting or just from a certain IP address? That will determine if the problem is on the client or server side. Is AVG anti-virus software running by any chance?
I tested the RSOIP using mp3 and Wi-Fi. Appears okay here. What OS version running?
BCasto
Morrisville NC
I will try that. I did think of that option but, maybe incorrectly, thought they would be using the same serial port address. But maybe it will work since each would be plugged into a different physical USB ports.
Thank you.
