ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
letarotor
Arlington, TX
Ok I guess I was thinking there was a pick list like in Sentinel. I'm trying to figure out how to copy over my SDS100 display color and layout settings to the SDS200.
I just watched a YouTube video the other day that does show these options on the color display changes in Sentinel are done. Let me see if I can find that link and I'll post it in this reply.
I'm unfortunately unable to follow this video because of my vision but I did save it so that I can go back through it and listen to what the guy is saying. But you should be able to see his examples in this link on how to do it with Sentinel.
Brian (COMMSCAN)
Sent from my SAMSUNG-SM-G930A using Tapatalk
mancow
N.E. Kansas
Thank you for the link. My issue was there was something wrong with the directory structure of the Sentinel install. It wouldn't open the editor. I reinstalled and it works now.
letarotor
Arlington, TX
I had not even looked at this capability in Sentinel and had not thought about about it. I had made my changes manually on my SDS100 and they transferred over thankfully to my SDS200 exactly identical. Even the D ERROR option that I had added to my 100 screen transferred over perfectly fine. But since I have very little vision, I'm thinking of using Sentinel and seeing what color schemes I can come up with to help even more than what I'm using now. Since it apparently shows in the program how it should look on the radio, that's a big plus and I didn't even realize it was there in the Sentinel software until the other day when I saw the YouTube video. It's nice to be able to have that kind of customization on the screen.
Brian (COMMSCAN
bagmouse7
NC, USA
So, it looks like the SDS200 does not provide the same streaming audio output via the rtsp://x.x.x.x/au:scanner.au URL when it is ethernet attached like the 536 does when it is wifi connected. I can control the SDS200 fine with Proscan, but I can't receive the streaming audio.
Does the SDS200 provide the streaming audio via a different URL or or this just not available on the SDS200?
phask
zanesville
Works fine for me - did you change the URL in the audio section?
ProScan
Software Provider
Ontario, Calif.
Do you have another app that is using the audio on the same scanner. Only one app at a time can use the audio.
eaf1956
Evansville, IN
It is finicky try turning the scanner off and back on. It does provide audio it just doesn't wasn't to connect the first try.
mule1075
Washington Pennsylvania
I think I am addicted to ProScan....
Sent from my SM-N960U using Tapatalk
That's the way I use to be but due to some unforseen things dwindled down my collection to near nothing but I am still addicted to ProScan myself. SDS 100 ProScan TeamViewer and a Tablet. Also a 125at
mule1075
Quick question for Bob about radiofeed. Can you add the 125at to the list of scanners.The source client detects the scanner i am using the 325p2 setting to send the tags and it works perfectly.
mancow
N.E. Kansas
Oh that's neat! I didn't realize it would work with the 125AT either. Thanks for pointing that out!
Unfortunately it won't download or upload but at least it will control it.
