ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
kb7gjy
Bonners Ferry, Idaho
Bob, the audio issue I have is not Proscan. Still trying to figure out the problem in windows. I click on Windows mixer, then click properties on my line in, Levels, and for some reason it Mutes it in the middle of the night.
I have no cats, so I can rule out a cat walking on the keyboard. LOL
eaf1956
Evansville, IN
I got 4 want a cat?
Sent from my SM-N960U using Tapatalk
slylingus
Just updated to 14.4 scanner specific for BCD536HP
Had a look in the manual
My stream was dropping out with upload & found these New options
What is the difference between Method 1 & 2
Many Thanks
ProScan
Software Provider
Ontario, Calif.
Many Thanks
Is the stream dropping with ver. 14.4?
Is that the Source Client or Web Server?
Are you using the Wi-Fi?
When did the stream start to drop?
Are you running AVG Anti-Virus software by any chance?
Stream dropping could also be caused ISP, cables, NIC cards, router, far end, etc.
Method 1 & 2 are just different methods of keep-alive's on the Wi-Fi. For experimental purposes at this time. Try method 1 for several days and see what happens. Later try method 2 to see which works better.
slylingus
14.4 yes Streaming wifi audio to source client on broadcastify.
Setting was set to off after update, That was my issue dropped out after scanner write.
Ive changed to Method one and that has fixed drop outs. (obviously).
I have noticed on the earlier version if running 3 instances of ProScan using wifi with BCD536HP Scanners
on the same windows 10 machine
That the stream will drop overnight, and not reconnect just attempt to many times over.
Not an issue but maybe I will trying different methods of keep wifi alive for that.
many Thanks I can't wait to use It with the SDS200
Cheers
buddrousa
Cheers
Are you running 3 instances of PROSCAN or just starting the same copy 3 times? I run 4 536's wifi 24/7 with no drop outs win 10 pro 64 PROSCAN 14.2 upgraded to 14.4 with no problems.
slylingus
Nice to no thanks yes starting the same Desktop short cut.
Mine was Windows 10 Pro as well
So if running three instances would that be a new ProScan folder for each Instances?
I've only been using WiFi & 536 for the last couple of months it did take a while to get WiFi going (location from router)
Similar setup 3 x 536 1 on stream WiFi has great sound IMO.
Running McAfee Total Protection.
Cheers
ProScan
Software Provider
Ontario, Calif.
Cheers
Each instance should be in a separate folder so each instance will have its own configuration and logging files.
eaf1956
Evansville, IN
I like the way the SD 200 works so well with ProScan. No darn WIFI dongle just straight LAN connection. Audio and Metadata all over LAN. Awesome job Bob!
mancow
N.E. Kansas
Ok I guess I was thinking there was a pick list like in Sentinel. I'm trying to figure out how to copy over my SDS100 display color and layout settings to the SDS200.
