ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
g1dtf
Rotherham, UK
Is there any limit as to the number of times the activation can be transferred between different computers. I have a main computer that i will run it on almost permanently and 2 laptops that I would like to swap activation between from time to time depending on my current circumstances.
Andy G1DTF.
ProScan
Software Provider
Ontario, Calif.
Andy G1DTF.
The activation process is not designed for that. It for replacing an old computer with a new one.
g1dtf
Rotherham, UK
Thanks for the info. Just got a 15x and currently in the 30day trial period of the software . With Xmas approaching is there any period where you will not be processing activations due to hols etc? Dont want to be left without the prog as I find it excellent.
ProScan
Software Provider
Ontario, Calif.
Activations are handled automatically. If it fails for any reason, email me. Activations are the highest priority. Any license or activation issues are handled via email only.
wbswetnam
DMR-istan
I love ProScan! I think it's fabulous!
Question: Is there any way to toggle between enabling / disabling entire trunked systems, and not just the individual towers of the system? I'd like to be able to do that with the area wide digital system for Entergy (an electric utility company).
My scanner is a Uniden BCD996P2, if that makes any difference.
Synchro39
Montreal Quebec
i have a new problem some time recording not working but i can hear it from web server but no recording in my record folder look like it's for DMR frequency and sometime recording work great like it supposed to do anybody have an idea where i should look i rebooted scanner and computer without any luck
rjdj2000
Gone Cuckoo
Central NY
I have been having some issues with 15.7 version, it will run perfect for a day or so then nothing, no audio nor display from my 536. I remember there was a Method 1/2 option in Options>Scanner Specific area but when I went there to change it, It was not there. This may also be a router issue but I have yet to track it down but was going to change this option to see if it was the problem. Anyone know where it went to possibly?
ProScan
Software Provider
Ontario, Calif.
Problem could be anything such as Wi-Fi Dongle, anti-virus software, Wi-Fi interference, computer Ethernet connection, etc.
When did the problem start? No changes with 15.7. May want to revert to 15.6 ort earlier to see if the audio and display data stays up.
May want to disable any Internet Security or Antivirus software for a test to see if it stays up.
Next time it goes down, I would do these steps to see if it recovers:
1. Power cycle the scanner
2. Restart ProScan
3. Power cycle the router.
4. Power cycle the computer.
rjdj2000
Gone Cuckoo
Central NY
2. Restart ProScan
Bob, I am not exactly sure when it all started as I can't remember when. As far as anti-virus, it is stock Win 10 stuff, computer is hard wired to router, WiFi to the 536 is about 15 ft away from router and has hard coded ip address. I have tried your steps you listed but nothing recovers it until either a) do a soft re-boot of router over web interface or b) a hard reboot by unplugging router power. Earlier today I flashed different firmware onto the router to see if that would help, so far it has been up and running. I know you had the WiFi Keep Alive methods in prior versions of ProScan but I guess it isn't available with 15.7 anymore. Will post back if it happens again, it is just frustrating to have it keep doing it when I have had virtually no issues with the scanner staying connected 24/7 - 365. I only had issues with the source side dropping out but that seems to be stable for now.
seagravebuff60
Forensic Scanist
SDS200 Error with ProScan:
Hello, all I just received an SDS200 for Christmas! I am having some trouble getting ProSan to recognize/Interact with my SDS200. All the COM Ports and everything is all set up correctly, but upon loading up the Favorites Editor in ProScan I get the following Message Below. Can anyone Please Advise on how to fix this so I can Edit And Interact with my SDS200 thru ProScan. Thanks and Merry Christmas!78387.
