ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
RandyKuff
Lorain, Ohio
Find this window in ProScan and see the box for "tone on capture side" I have ckecked... Make sure loopback is checked...
See if it works before thinking it's the jack...
ProScan
Software Provider
Ontario, Calif.
It does not sir. It shows that it is enabled, but cant get audio to show. Unless I am doing something wrong. This is on the line in jack as well as using the USB sound adapter that I listed above.
I would check that the Win Mixer is showing as an input(mic) and not output(speaker). My guess is the scanner jack and/or cable.
spywiz
Deep Run, NC
The audio works fine from the scanner to an external speaker. The mic works fine from the computer on a skype call. The speakers work fine on the Surface Pro. But I get nothing to the audio in the Proscan. Note: I do not have any of the ip stuff set up yet. I only checked the audio on the "tone capture". I'm pulling my hair out.
spywiz
Deep Run, NC
USB sound card.
RandyKuff
Lorain, Ohio
Just a test...
On your input setting change it to "What U hear" and try the tone test again...
That should verify that ProScan is working...
If that works... Something with the input settings is not right..
spywiz
Deep Run, NC
This is all there is. It is the USB card, and the one below is the default.
