ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
kruser
Well Known Member
W St Louis Cnty, MO
Does anyone else get RSSI readings in the 400 to 500 range in the history logging area? The aucutal RSSI of the signals im getting should be around -50 to -60 not 400 to 500. Im using 2 BCT15xs via the rear serial port but using the front its the same
I don't think the RSSI values that ProScan logs are really a calibrated value. The scanners simply don't output those type of values.
The SDS models claim to display dBm but they are often way off if other signals within the tuners passband are influencing the signal reading.
My x36HP and the XT series usually show a value in the 200 to 300 range for strong signals while weak signals are usually in the lower 100 range.
GTR8000
NY/NJ Database Guy
BEE00
I see 400s all the time on my 536HP from strong local repeaters, not unusual.
As has already been noted, only the SDS series show a dB value like -50 and -60, all other Uniden models show the Uniden scale of 0-500 or whatever it is.
ProScan simply captures whatever RSSI value the scanner is outputting, it does no calculation or anything else on its own. You can see this raw RSSI value coming from the scanner on the Test & Extras screen in ProScan. Look for the line with the PWR value.
Chris0516
Pittsboro, North Carolina
Bob, Utilizing Proscan, why is it, in the History log. With my trunked systems, it shows 'what's in the trunk'(System/Group/TGID). But, With the UHF/VHF frequencies, it only shows the name of the system? I know the easy answer would be, because UHF/VHF frequencies are not trunked. But is there a way in Proscan to make the Groups and Channel Names show up?
TIA
ProScan
Software Provider
Ontario, Calif.
TIA
Groups and Channels should appear. Is that with a UBCD325p2? Perhaps the grid is not scrolled fully to the right or the program width needs to be wider so it can be viewed.
Chris0516
They should appear. It isn't a width problem. I double-checked the TGIDs' of the recorded entries with no 'info'. I couldn't find the TGIDs' in my Proscan database.
ProScan
Software Provider
Ontario, Calif.
Are you talking about the History grid or Recording grid? I'm not really clear on the issue here. History grid showing the groups & channels text tags here.
Chris0516
I looked at the Recording Grid. To compare the History Grid to it. In the History Grid. The System/Site-Group-Channel, is not always appearing with the TGID. It will show up in one entry, but not another entry,
Look at TGID 16500. Where 16500 is highlighted, it shows no 'info'. Look further down. You will see all the 'info'(System/Site-Group-Channel). 4169, Is the local barracks of the state police(I think).
ProScan
Software Provider
Ontario, Calif.
Do you see it in the Recording grid?
ProScan
Software Provider
Ontario, Calif.
Perhaps the group and channel text tags didn't arrive from the scanner. You may want to turn on the Scanner Data To "Scanner Data.txt" File option. Option located in the Options - General tab. That way you can look at the incoming data to confirm.
ProScan
Software Provider
Ontario, Calif.
It is just showing one system. But no other systems'. While other systems' do exist on the scanner.
If it logs the system in ProScan then it will show up in the file 100%. You may want to power cycle the scanner and perhaps check if the scanner firmware is up to date to see if that fixes the intermittent missing info.
Chris0516
The Firmware has been up-to-date, for some time. I power-cycled my scanner, and re-started Proscan.
Synchro39
Montreal Quebec
i have a problem for some time now when i listen to my web server the sound cut like if close call is activated but it's not the case and sometime the display on the web server come black and come back by his own it's really annoying anybody have this problem and know how to solve it
when i listen to the scanner directly the sound is perfect i think i will try to downgrade one or two version i am now with 16.8.1
