ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
rn1nduk1
Texas
Unless I missed it, question. I got the Broadcast lockout to work. Kewl feature. Add or remove # and resave and works. Is there a means by which if the control channel on the frequency it lands on, if it has the "E" flag, it can auto lockout until the "E" flag is no longer detected? "E" meaning emergency (may show different in proscan)
hiegtx
Dallas, TX
The E as used in the database is for Encrypted, not Emergency.
A control channel, on a trunked system, is used for all communications on the system. It is not dedicated to any one specific call type. It directs transmissions to one of the voice channels on the system.
If you are referring to encrypted transmissions, Uniden scanners skip those by default. The scanner may pause very briefly on a talkgroup, then, if it detects encryption is in use, it moves on. While those encrypted 'hits' are normally logged in ProScan, the scanner may pause so briefly on an encrypted transmission that you won't even notice it.
rn1nduk1
Texas
maybe stated wrong. Was not referring to database. Some software shows differently, but does change a priority on the system when emergency traffic is detected to ensure if all channels on system in use, bumps lower priority out and priority traffic goes thru. Maybe need to look at logs in proscan to see how is in control channel log.
ProScan
Software Provider
Ontario, Calif.
maybe stated wrong. Some software shows differently, but does change a priority on the system when emergency traffic is detected to ensure if all channels on system in use, bumps lower priority out. Maybe need to look at logs in proscan to shows how is in control channel log.
Are you refereeing to the Emergency Alert Tone & Light on Moto & EDACS systems or the Alert Tone & Light at the channel level on all systems?
ProScan database terminology should follow the scanner database terminology exactly.
{edit} The Broadcast L/O function locks out any channel in the file.
rn1nduk1
Texas
On all systems. In effect, what you said. It may not be a feature of Proscan. Some "tools" get out of the control channel a call type. Can be a number only on the channel in use by the talkgroup, of the priority, but changes in some as E followed by a number of the priority indicating emergency with a priority. But like earlier response, the control channel output shows encrypted, so doesn't unmute scanner on that talkgroup. Still comes from the control channel output. Was thinking since proscan can do control channel output, could have scanner not rebroadcast anything with that type of traffic on it. Sorry for confusion. I was not referring to RRDB E. Was strictly related to control channel output.
My goal would to be auto lockout that type of traffic on the stream. Most times, my area, they dont have dispatchers to move to another channel, so main dispatch they work off of and may have dogs tracking, etc. Was an officer safety idea for my feed. Some idiot turn on feed and hear them closing in. The lockout file works well though. Just had idea if way to broaden that concept. Other reason of thought, was some idiot in scanner radio app posted feed alert which sent out notifications on app of incident. When rolled back recordings, was stuff I preferred not to have been streamed.
ProScan
Software Provider
Ontario, Calif.
ProScan doesn't analyze the C-Ch Output. ProScan can turn it on or off and write the data to a file. The problem with the C-Ch Output is that it streams continuously and therefore clogs up the serial port causing the logging, broadcasting text tags, display, etc to slow down.
rn1nduk1
Texas
Okie Dokie. Thanks for feedback.
rn1nduk1
Texas
I just thought of something. As it is now, the C-Ch Output is supported on just the XT and P2 scanners. It would be a Kewl feature if the scanners that are Ethernet capable support the C-Ch Output through a firmware upgrade.
Sorry. Didn't mean to give you work with my crazy thought idea if was capable. haha
Yocuz
Gloucester County NJ
Hello
I am looking for some information regarding the minimum requirements to run ProScan. I am contemplating repurposing an old iMac (2009 10,1) to become a straight PC machine. I am currently debating using bootcamp or making the device a native windows machine. In any case here are the specs.
3.06 Ghz Intel Core 2 Duo
16GB 1067 MHZ DDR3
250GB SSD
Windows 10
Does this meet the ProScan minimums?
ProScan
Software Provider
Ontario, Calif.
Hello
16GB 1067 MHZ DDR3
250GB SSD
Windows 10
More then the mins.
ProScan
Software Provider
Ontario, Calif.
Installed 17.2 and lost most of the fonts ?
I believe you are referring to the font names in the Options? Ver 17.1 shows only the monospaced type. Variable width types don't show correctly in the virtual display as they don't align correctly in the virtual display and some characters like the "W" is clipped.
  • Changed - Display font selection box in the options now shows only the monospaced fonts.
Dan_M
Derby
Bob,
Is there any change that the play back recordings that could be modified to a variable play back speed.
Dan
ProScan
Software Provider
Ontario, Calif.
Bob,
Dan
{edit} Let me add that I have no ideal how that works. Is this for mp3 recordings only? Does anything need to be done on the recording side?
If that's a suggestion. here is the Bug Reporting and Suggestions guidelines
Dan_M
Derby
it is a suggestion to add to play back so when people talk to fast you can slow down the recorded audio on playback.
