ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
03msc
RF is RF
The Natural State
The more I use ProScan the more I like it. Very feature rich, much better than Sentinel. I hate that some things still must be done in Sentinel. But...ProScan is great!
I did determine that I can do what I was wanting to do - just File > Save as... > and create a new file for a different scanner. Then I can change the favorites, etc., in it (including turning location on/off on some) and it saves. Then I can open another to edit programming of another scanner. I probably wasn't clear when I asked previously but that was my goal and it seems to be working fine.
Tjboisclair
Sorry if this has been asked before in this huge thread, but I'm more often than not finding that my recordings for a given station with activity is always small little segments of a few seconds.
Basically, every time someone breaks or even if there's a little moment of silence a new recording will start up. Is this something fixed with the Skip Silence Threshold? If so, is there a trick to it? I know it must vary for location and signal strength but I have mine set at pretty much the noise floor (7 for me) where anything above is guaranteed to be actual activity.
Is there another setting I'm not finding? Like for instance a setting that waits x amount of seconds between activity before ending and starting a new recording on the same channel?
I'd just like to be able to take a conversation on a particular channel and have that string of activty without needing to always stitch together segments every time someone unkeys for longer than a half second. SDS100 if that counts too.
Attached example if it helps in understanding, this is just a short two way conversion that's cut every time someone breaks. I'd like it if every instance was recorded as one recording, ie a setting that waits x number of seconds before starting a new recording, like how the scanner waits on the channel.
gootch
Sun Prairie Wisconsin
Do you have this setting checked on the right side of the recordings tab? Also in the options then recordings tab you can specify max recording time that will start a new line when that threshold has been met.
Tjboisclair
I have a long enough threshold in the settings. I have Each Trans. New Row checked because otherwise that will just append on to each time a channel has activity, correct?
My hope is to somehow configure it so it will record like the SDS100 does internally, one recording for each time it stops on a channel.
Tjboisclair
This issue actually seems to happen more often with conventional channels. P25 and DMR especially not as much. a DMR conversation just now seemed to hang with an orange highlight for a bit before ending the recording.
ProScan
Software Provider
Ontario, Calif.
Try unchecking the "Each Transmission New Row" option then go in to the Options - Recorder tab then add %FT (or %TG ) to the Custom Filename Format. That way, each recording is a different talk group ID and conv. frequency.
The recorder will start when the scanner sends the activity flag in the on state and will stop when the scanner sends the activity flag in the off state. You may want to experiment with the channel delay time
ProScan
Software Provider
Ontario, Calif.
Is it possible to do a search for entry in the History.log, w/o having to endlessly scroll looking for an entry in the log?
What type of data are you looking for?
The columns can be sorted by clicking the column header so it will make it easier to search.
{edit} An option "Logging To 'History Log.txt' File can be turned on so the file can be searched with a text editor.
Tjboisclair
Good tip, but for conventional it doesn't really help.
That's what's strange. I have the default delay time on my SDS100 of 2 sec for most channels and it will hold a channel fine but ProScan is stopping and starting new recordings after every break or other short silences while the scanner is stopped on a channel.
ProScan
Software Provider
Ontario, Calif.
It should work. It works here. When the option "Each Transmission New Row" is unchecked, the different conv. frequencies are in separate rows.
The recorder, history logging, and the activity border around the display are all triggered from the activity flag received from the scanner. Can you see if the Activity border around the display turns on when the scanner is on a channel and turns off when the scanner is scanning?
I would power cycle the scanner just in case.
