ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
belvdr
It works here on Win 11. I'll wait and see if anyone else runs into this problem.
I found a solution. I have the Windows firewall disabled, but after I added proscan.exe to be allowed in the firewall, auto-detect for IP works. It seems disabling the Windows firewall doesn't mean fully disabled.
ProScan
Software Provider
Ontario, Calif.
I asked this in a separate thread but realize in may belong here. I am trying to update some GPS coordinates using the maps but when I click on "Update Node", nothing happens. If I close out and reopen the same group I am trying to update no change is made. I also notice that the X button in the top right is all grey. I am running the latest version on windows 10.
I'll look at this before the next release.
NoahWL
I ran into this too, using v20.1. A workaround I found is to uncheck "Use internal web browser." I'm using Firefox as my default browser, and the "Update Node" button works in that.
Reconrider
Inside the Galaxy
Radio Galaxy
I figured out a feature that @ProScan needs.
Sentinel can lockout private calls by adding a talkgroup of "i0" and clicking avoid, but proscan removes the "i". Anyway to enable this character in the talkgroup box?
I can email to you also if needed.
ProScan
Software Provider
Ontario, Calif.
I'll look at it before the next release.
ProScan
Software Provider
Ontario, Calif.
sds100 in p25 trunk systems.
in proscan it autoremoves it when you save it
I can't duplicate it. See this link and attach a screenshot of the window that it happens on.
Reconrider
Inside the Galaxy
Radio Galaxy
Will do. It'll be a few hours before I can get it done but at some point I will.
Reconrider
Inside the Galaxy
Radio Galaxy
My fault. It's NXDN48 not p25.
I just tested it
Before hitting enter to save TG: Screenshot
After hitting enter to save TG: Screenshot
ProScan
Software Provider
Ontario, Calif.
ProScan Version 20.2 Just Released!
  • Added - 'Menu Top' command to the Shortcuts menu sequence.
  • Changed - Low latency (1.3 second) audio player on the Web Server web page.
  • Fixed - Google Maps Update Node button wasn't working with the internal web browser.
ProScan Website
ProScan is the most powerful and feature rich scanner software in the world !!!
NoahWL
ProScan Website
You're awesome. Thanks for all your hard work!
ProScan
Software Provider
Ontario, Calif.
Hello how do I delete this when opening up favorites editor
Unable to open favorites list
C:\users\jeff\onedrive\desktop\SDS100\f_list cfg
If you want the Favorites Editor to stay open and just the message to go away then go to File menu then click on New or Open then choose a folder then click on New.
If you don't want the Favorites Editor to open then go to the Options - Startup tab and uncheck the Database Favorites box.
yorky
Hello! I'm currently running version 14.4 multiple times on the one PC, however I just wish to update one of the copies on the PC to the latest version. Am I able to do that?
