ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
GTR8000
NY/NJ Database Guy
BEE00
You can always upgrade to the latest version no matter what you're currently on. Sometimes if you wait a long time there are a ton of features and changes you need to catch up on through the release notes, but otherwise...jumping up multiple versions is not an issue.
KC4ASF
Fredericksburg, VA
ProScan Version 20.6 Just Released!
  • Fixed - Web Server - The scanner buttons on the web browser weren't working correctly because the hotspots weren't not aligning correctly.
  • Changed - Recorder - Stopped writing MP3 ID3v2 tags to the recording files if the Title & Artist boxes are blank in the Options - Recording Text Tags tab.
ProScan Website
ProScan is the most powerful and feature rich scanner software in the world !!!
I updated and now each recording is only for 1 mike keyup. In other words each recording is only a few seconds for each transmission.
Make any sense?
ProScan
Software Provider
Ontario, Calif.
Make any sense?
What version worked for you before?
Can you revert back to see if it does the same thing?
What is the scanner type?
Are you recording in mp3 or wav format?
Pittsburgh, Pennsylvania
Make any sense?
I'm having the same issue. Every transmission generates its own file row instead of appending to the "daily" file. Previously worked on version 20.5. Windows 11 / SDS200 / saving as MP3.
This might be nothing, but I see a Proscan\Recordings\<Recording_Date>\ file system listed as the recordings location, but in explorer there isn't a Recordings subfolder at all. I don't know what this looked like before, though so take it with a grain of salt. I can actually listen to the recordings. Wherever they are.
I have reverted back to 20.5 and will report back on the recordings.
737mech
Clark County, NV.
Just want to say thanks ProScan for version 20.4 and newer. I was having a hard time explaining the metadata settings to a few friends. Nice how it works now!! Keep up the great work and improvements!
KAZ7ED
I have been using ProScan since the beginning. Great software product! Is there an opportunity to add the HomePatrol scanners to it?
ProScan
Software Provider
Ontario, Calif.
I went back to 20.5 and it is recording great..
It is a 536.
Recording is wav.
Can you send a bug report to my email address so I can send you a test file or two.
Bug Reporting
If you discover a bug, send an email to support@proscan.org. The advantage of email is so I can ask questions and send you production quality files with additional testing to help fix the bug. The person reporting the bug will get the fix sooner than waiting for the next release. Put "bug" in the Subject line.
Bug Reports - Advise on the following:
Product (ProScan, Free Client, or RadioFeed):
Version:
Scanner type:
Scanner firmware version (if applicable):
OS type:
Options pertaining to the bug:
Describe in detail what the bug is doing or not doing:
FFgreg2003
Hazleton, PA
I'm having trouble with updating. I have done this many times without issue. I'm getting a few errors. The first one being something is using proscan.exe and it asks me to close it. I close it and then I get errors on proscan.exe and lame_enc.dll saying error code 5 delete file failed. Any ideas? When asking to close, nothing is running related to proscan per task manager.
dave3825
Suffolk County NY
You may want to wait as others are reporting an issue with recordings.
If you don't do recordings or just want to update regardless, try rebooting the pc, don't start proscan, then try the proscan update file that should have saved to your pc.
