ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
ProScan
Software Provider
Ontario, Calif.
Running the new version on Windows 10 computer on both an EDACS system with some P25 conventional. I have both recorder options turned on. I get files for the trunked activity in both folders but the ones in the UID recordings folder will not play. I get an error that the file type is not supported. TheUID recorder has size that closely matches the other recording but does not play
I can't duplicate the problem. I wait and see if any others are experiencing problems in this area.
{edit} Can you determine if the problem is on the record side or playback side by doing this. Click the File Explorer button (located far right in the UID Recorder grid) then in the File Explorer window, try to playback the file. If it doesn't playback then the problem is on the record side. If it does playback then the problem is on the playback side.
cg
Connecticut
I had done that and the file will not play via ProScan interface or via file explorer. Also, I moved a couple of the files to a Windows 11 computer to test and nothing works there either. I also tried multiple players with no luck (WIndows Media Player, Media Player, and VLC media player.
I sent you my .CFG file and a couple samples
Pr999
Just love radios
Allegan County, Michigan
It seems dark mode has made this ever so buggy. I can't see sliders or text half the time. I think this still needs some tweaking before being official.
Also, I'm having trouble getting working audio for RSOIP, my issue is it shows audio playing but I can't hear it at all.
Edit: nevermind, I fixed the second issue.
03msc
RF is RF
The Natural State
It may seem unnecessary, but...if you haven't, I would suggest a computer reboot and test again just to be sure. I've seen things happen like that and a reboot clear them up. If it's still an issue then Bob will probably want to know the specific version of Windows you're on, etc.
hazrat8990
Wyoming
I just did the update and have lost the ability to simply log UID's. Not everyone uses, or has the ability to set up audio recording via URL, or other means. This is very disappointing since I don't see a way to work around it. I do like this version for the one scanner that is connected via WiFi, but for the others, it's totally useless to me. I would like to go back to the previous version for the other instances, but I no longer have a copy of the install file.
jtwalker
BEE00.1E8-1.22 (or) BEE00.689-1.13
UID's are logged on "history logging" tab.
hazrat8990
Wyoming
I am very well aware of that, but it is not even close to usable for me since UID's have never been able to be edited from that tab on any version that I'm aware of. One of the main reasons I purchased the software was because of the ability to log, edit, and import them to the database. With this new version, that ability is lost for those who are connected via USB.
hazrat8990
Wyoming
Guess you should save old versions. I am pretty sure Bob can send you a link to a previous version.
I usually do, but I ended up cleaning up the downloads folder. Fortunately, the Wayback Machine came in handy. I am now running both versions. Like I said before, I do like the new version, but still need to use the older one for the USB only connected scanners in order to log and edit UID's.
W4GFQ
Hi guys n gals, does anyone know if you can have the audio muted on the unit but sound for the computer only?
Leveraging the question, I see the record indication for UIDs being recorded but when I hit play I hear nothing out of the computer. What am I missing?
ProScan
Software Provider
Ontario, Calif.
It's fixed. It will be in the next release. For a workaround, choose the mp3 format and not wav.
jtwalker
I don't notice any loss of functionality in UID logging, and the ability to edit and update the database, etc. I do have audio being recorded and it sounds like you don't, so this is the only point for which I don't have a direct comparison.
N9JIG
Sheriff
Moderator
Far NW Valley
ProScan Version 23.0 Just Released!
  • Added - Dark Mode option - Option located in the Startup options.
  • Changed - Renamed the UID Logger to UID Recorder as it now records the audio.
  • Changed - 'Active Row In View' option changed to 'Active Row At Top', 'Active Row In View', & 'Active Row At Bottom' on all logging & recorder screens.
  • Fixed - BCD160DN - 226 MHz to 399 MHz range wasn't recognized as valid when importing or using the Frequency Tune function.
ProScan Website
ProScan is the most powerful and feature rich scanner software in the world !!!
Thanks Bob, the Active Row item fixed an annoyance that bothered a couple of us!
