ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
engine183
Mount Orab, Ohio
I’m a member of a scanner club in the greater Cincinnati area (Monix). We are always looking for more information on scanners and programming software. Many of our members either have or are interested in PROSCAN. The software is so powerful, I’m sure it does things that we are not aware of. We were wondering if PROSCAN has a speaker’s bureau that could participate with our scanners group via Zoom?
Nascar18
Southeast Massachusetts
Hi Bob, I got my new Dell pc up and running. I connected the SDS200 to Proscan and read from the scanner to get a favorite list in ProScan. I go and use it tonight and I can't get a com port. I try thr Proscan with my 996P2 and it was fine. I used Sentinel with the SDS200 and the com port was there and worked ok.
Any ideas!
ProScan
Software Provider
Ontario, Calif.
Any ideas!
You mentioned "com port". The comm. port (or serial port) is not used with Sentinel. ProScan uses the comm. port for the virtual display, and logging.
Are you trying to read or write the favorites from the scanner or trying to get the virtual display, and logging working.. If trying to read or write the favorites, is the scanner in Mass Storage mode? Can you access the scanner SD card using File Explorer?
ProScan
Software Provider
Ontario, Calif.
Bob, I am going to uninstall the ProScan and re-install it. I think the One Drive was backing up the files.
You never answered my questions. It's hard to troubleshoot without knowing what you're doing.
I never recommend uninstalling and reinstalling ProScan, all that does is replace the exe file.
ProScan
Software Provider
Ontario, Calif.
In what situations would this feature be activated? Can you provide examples?
It was a request. Someone with a hacked firmware, allowing continuous band coverage. Also may be used for scanners that ProScan doesn't support directly such as the UBCD160DN. Anyone using the UBCD160DN has to set the scanner type to BCD160DN and that model, I haven't looked it up, but I'm sure the band coverage is a little different.
JamesWest
Hello Mr. Proscan. :) I have a SDS-200 running with Proscan and it is an amazing combo. Well worth the $50.
My question is: I am thinking about buying a Uniden BCT15X running Close Call in my truck all the time. (I am very interested in near field transmissions) Will Proscan log the Close Call hits the same way it does with the SDS-200? All I am interested in is the frequency. I am assuming the history logging tab is basically the same? I will be using a small notebook computer.
Thanks for a great product.
BinaryMode
Banned
2600 dialtone blvd
Yeah, it'll work.
I have a BCD996P2 in the vehicle with Close Call on all the time and it hardly gets anything. When it does it's kinda annoying sometimes due to digital data or whatever so I have to try and lock it out while driving. And for me, I personally don't drive and use a cellphone - and try and make coffee... In other words, my hands are always on the wheel because I know it takes just a second. I even pull over to use a cellphone. I'm very paranoid about that. I've been in a car accident of no fault of my own and it's no joke. I shouldn't even be here...
So yeah, it'll work, but can be distracting at times. I even picked up someone's home Ham repeater on 1.25 meters.
I'm not familiar with the SDS line of scanners, but if they're like the P2's go to the settings and find the "Tone/Code Search" option in Close Call and turn it off. If for example it's set to NAC/CC/RAN/Area, Close Call will ONLY Close Call capture on a digital transmissions. Like wise, if it's on CTCSS/DCS it will ONLY capture analog and not digital. So with it off you get the best of both modulation schemes minus the ability to see a subcode. Whether that be analog or digital voice.
Firebuff66
CT
Anyone getting the message that i posted below?
Wondering if is a Pro-Scan thing or windows, I have 16 scanners remoted with Pro-Scan and it will randomly happen to any one of them. I just upgraded all of them to the newest version and that's when it started
ProScan
Software Provider
Ontario, Calif.
Wondering if is a Pro-Scan thing or windows, I have 16 scanners remoted with Pro-Scan and will randomly happen to any one of them. I just upgraded all of them to the newest version ands that's when it started
I'll look at it before the next release.
mrlindstrom
Klein, TX
Hello,
I sent an email a couple weeks ago regarding having to rebuild my PC and now I'm stuck with the "Maximum Installs Exceeded Per The License Agreement" message. Is there a way to clear that old install out of the backend as the drive in my PC failed and I can't boot that OS install any more.
