ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
ProScan
Software Provider
Ontario, Calif.
I deleted the program and reinstalled it, added my key and the main screen is grated out where I cannot access anything other than file or new. Not having any luck. The upgrade definitely does not like Windows 11 Pro.
Can you post a screenshot.
Did you go to File then Open and navigate to the FL like I advised in my other post?
You don't need to uninstall when upgrading ProScan versions.
mjdewey
Scanner Radio Man, ComL, ComT, Auxcomm
Bluffton, Indiana
This was the first attempt to use the program on this computer. It is new. I installed it set up and entered my key. There is no favorites list on this computer yet. I was trying to read from the scanner and it won't work.
I have photos of screens but the are to large to send.
ProScan
Software Provider
Ontario, Calif.
Go into the File menu then click on New then in the "Browse For Folder" dialog, navigate to where you want the FL to be then click on "Make New Folder". Give it a name then click OK. Now it should work.
03msc
RF is RF
The Natural State
I believe it only allows installs on a certain number of computers (two?). Could it be that you reached that limit already? If it was on a computer you no longer have or no longer functions but you didn't remove the license from it, Bob can clear your license on his end so it will work on your new computer. Unless I'm misunderstanding, I'm wondering if this isn't the issue? // @ProScan ?
RMason
Mississippi / Colorado
The OP's issue is that he does not have a Favorites List open:
From the Proscan user guide:
Before data in a Favorites list can be written to the scanner or read from the scanner, the Favorites Editor needs to be opened and a Favorites folder needs to be opened.​
1.Go to the Menu --> Favorites Editor.​
3.If creating a new Favorites list: Go to the Favorites Editor Menu --> New then navigate to the folder, type in a file name, and click the OK button.​
ProScan
Software Provider
Ontario, Calif.
ProScan Version 24.6 Just Released!
  • Added - Web Server & RSOIP - "Test published server is reachable from the outside" button.
  • Added - BCD160DN, BCD260DN, UBCD160DN, UBCD260DN, BC125AT, UBC125XLT, & UBC126AT scanners - Move Selected Rows Up or Down.
  • Added - HP & SDS scanners - TDMA Slot to the Site Frequency settings for DMR One-Frequency systems. BCDx36HP firmware doesn't support this yet.
  • Added - HP & SDS scanners - Type field to the Band Plan for P25 Trunk systems. BCDx36HP firmware doesn't support this yet.
  • Added - Celsius option to Battery Temperature (SDS150). Located in the Profile Editor Display Customizer.
ProScan Website
ProScan is the most powerful and feature rich scanner software in the world !!!
avery_k
Broadcastify Feed Provider, Lake County, OR
Lake County, Oregon
ProScan Website
Yes! Thank you!
blueline_308
Eastern, NC
@ProScan I think I found a bug.
When I set 'Key Beep' to OFF in profile editor, it writes as AUTO in the scanner. This happens when I have set it to OFF in the scanner itself. This is with a SDS200.
Jim
