eaf1956
Evansville, IN
These are the ones I know I cannot connect too.
kc9lvx.dyndns.org on port 5000
kc9lzj.ham-radio-op.net on port 4500
Any other seems okay for me.
The 1st one is mine and it should work. The other one is my brother Mike and we (meaning I) am always driving up there to work on that feed. At the current time assuming he hasn't changed anything it should be working. He keeps changing ISP's and Cable modems and routers and I constantly have to adjust which ports are able to be used. But, as far as I know both of the feeds are working at this time. Some of the problems with kc9lvx.dyndns.org is that I sometimes forget to log onto the DYN site to keep it active (Every 30 days) I will check them both out as soon as I get off of RR.
kc9lvx
Steve2003
Colorado
I would bet he let his DynDNS run out, I know on mine (no-ip.org) I have to go to their page once a month and do a captcha to keep it up and running. You may try emailing him, his email is posted on his qrz page if you can not see it message me and I will send it to you.
Sometimes your computer will still be using the old "cached" IP for the host name. Running "ipconfig /flushdns" (without quotes) from a command prompt will make it lookup the IP address again.
eaf1956
Evansville, IN
kc9lvx
Ok the IP address changed on the FEED computer and I had to redo the port triggering to that IP. As of right this moment it is working.
Another issue hmmm Proscan update showed port 5001 but I was using 5000. Manually changed my client to 5000 and it worked. Changed the server to 5001 just so they match and it works. So now I guess I will just leave it at port 5001 on the server side because for whatever reason the client sees 5001 even with the server set to 5000 and doing the update button.
As far as kc9lzj, I guess I will have to drive the 100 mile roundtrip to see what he did this time.
eaf1956
Evansville, IN
So.... what the heck is this all about??
Bob is aware of this issue as I had the same problem. Norton is supposed to be fixing their database in a future update. Bob says it is a false positive.
eaf1956
Evansville, IN
Give teamviewer a try it is a great program and free for non-commercial use. Save you many miles! and it is so easy to use on both sides (no router setup or anything)
I have to log into his router and cable modem and check the port triggers and the local IP address of his feed computer. Seems to change every time the modem resets or the router resets. Tried to have it permanently assigned the same IP but his router doesn't want to do that. It also involves OPEN PORT check from his IP address just to verify the server can be seen. And no I can't talk him through it, God knows I have tried.
ak4fn
Fredonia, KY
Send him this
HTML:
 http://ninite.com/teamviewer/
it will auto install it for him, then when it is installed, just have him start it (have him click the shortcut on his desktop) and it will show a nine digit number and a 4 digit number have him read both to you and you will be able to connect to his desktop and do everything you just mentioned from your desktop.
too803
Yours is back up and working :).. Thanks for putting it back up, gonna help me through some work nights. lol
eaf1956
Evansville, IN
I put some conventional channels online for Vanderburgh County they may or may not remain depends on how they work out. A lot of the fire repeaters have iffy reception. Mostly it runs on a YAGI pointing North toward the Evansville Safe_T tower and it is 800 MHz. (It's a 800 MHz Yagi)
too803
Sweet, I live out in Vanderburgh county so the volly fire tac channels are my favorite. lol
ProScan
Software Provider
Ontario, Calif.
BCD536HP Support
Here is the latest update on the BCD536HP support. It's moving along nicely and it should be ready in about 4 to 6 weeks. I just have to finish the Web Server and a few miscellaneous items.
After the 536HP is done then the BCD436HP will be next. The database for the BCDX36HP line will be missing. I started doing it and found soon after that it's almost a mirror image to the Sentinel program. It can be done if there is a demand.
The Web Server is getting a make over with the virtual scanner displayed on the web page. All buttons and knobs are operational. Now, No longer do you have to be logged in admin. mode to monitor and/or control scanner.
Screen shot of the Web Server web page:
eaf1956
Evansville, IN
my BCD536HP is on a VHF/UHF Omni and I listen to all kinds of things that are not on the feed. Ky State, Henderson Ky, Posey and Warrick Counties you get the idea...
AA6IO
Cerritos, CA (LA County)
I have not looked at this thread in a while because I thought Bob was not going to do anything right now with the 536/436HPs because of his time constraints. I love ProScan and use it quite a bit for my 996XT. Just happened to look again and I see that you (Bob) are moving quite rapidly on the 536HP version. Looks very impressive, and now I am very excited. Thanks so much for spending the time Bob to do this. It will make the new x36HP experience that much more enjoyable.
Steve AA6IO
eaf1956
Evansville, IN
Steve AA6IO
Maybe we need BOB to work on the siren APP for Uniden...
