ProScan
Software Provider
Ontario, Calif.
Bob
ProScan
Software Provider
Ontario, Calif.
Great work Bob !!!!!!
I took Proscan for the Windows 7 Beta Test with a Uniden BC 250D and it worked like a charm cant wait to get the 1.8 .2
Keep up the good work !!!!!!
Christopher
Thanks Christopher, I will do exactly that.
Actually ProScan Version1.8.2 is out.
Currently working on 1.8.3.
ProScan
Software Provider
Ontario, Calif.
ProScan 1.8.3 now available
ProScan 1.8.3 latest additions and improvements:
  • Changed the recorder from mono to stereo
  • Added an Audio Control tab showing a block diagram of the audio flow with level indicators and volume controls.
  • RadioReference database import conforms to the RadioReference web service version 3.1.
  • Added a RadioReference database search.
  • Added a direct frequency tune control to the DMA scanner types.
  • Added shortcuts to the recorder Play, Stop, and Next buttons.
  • Recorder shows the file playback in green.
  • Added a font selection to the display options.
  • Fixed a bug where the talk group logging hits was not updating properly.
Many more improvements and small bug fixes.
ProScan is the most technology advanced Computer Aided Scanning software that’s feature rich with the friendliest user interface.
Try the 30 day fully functional trial and see for your self.
ProScan supports the BCD996T, BCT15, BCD396T, BR330T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D Scanners.
oilmillcharlie
Southern RI
Bob,
Any chance that the GRE DMA scanners will be added to Proscan?
B.K.
sfreiman
Tucson, AZ
I've added several items, many are user requested.
Import UASD files (all types) to ProScan (DMA and non-DMA scanner types)
Multiple sound cards support (capture)
Recorder user selectable filenames format
Recorder option lookup record flag from database
Recorder no loss
Quick Key assignment shows quick keys in use (DMA scanners)
Caption ICON user selectable
ProScan Sessions Manager
ProScan supports the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D Scanners. ProScan is feature rich with the friendliest user interface.
www.proscan.org
Bob
Cool! Love the software by the way. Wish that it could control a BC898T. I want to get an '898T but can't live without using ProScan with it!
ProScan
Software Provider
Ontario, Calif.
You quoted items added from several versions back so I'll repost the 1.8.3 new items added.
ProScan
Software Provider
Ontario, Calif.
Bob
did the ProScan 1.83 update complete the re-banning or is there a forth coming update for this ?
I've had no issue, just asking.
It's finished for the 996, 396, and the 15.
296 and the 796 will be in the next release.
330 not done yet.
AstroDude
British Columbia, Canada
Hello,
I just downloaded and installed ProScan to operate my Uniden BCT15. I have only been using it for 15 minutes and I can already make a couple of comments. "Professional" and "IMPRESSIVE".
If things continue with the way I belive they will, you should be seeing a purchase in the next day or two.
Thank-you
ProScan
Software Provider
Ontario, Calif.
ProScan 1.8.4 Full Version and Free Client Now Available
Latest Improvements
  • Added - RadioReference CD Import - (RadioReference web import previously added).
  • Added - BC296D / BC796D rebanding firmware support (BCD996T, BCD396T, and the BCT15 rebanding support previously added).
  • Added - Hot Event enhancements such as button turns red, 12 hour timeout, send type of alert, control client turn on/off hot event, and audio alert.
  • Changed - Recorder Options - stereo, mono combined channels, mono left channel, and mono right channel.
  • Fixed - Intermittent hang on unload.
  • Fixed - Moving mouse scroll knob in mode 1 or 2 causes a mouse click on the virtual knobs.
  • Fixed - Recordings distorted if the mono check box is unchecked and client connected to server.
  • Many more improvements and small bug fixes.
ProScan contains the most features in the industry. Try the fully functional 30 day trial. No obligation.
ProScan supports the BCD996T, BCT15, BCD396T, BR330T, BC796D, BC785D, BC780XLT, BC296D, and BC250D Uniden Scanners.
KI4LIV
Melbourne, FL
Sheer morbid curiousity - I wonder - would it be possible to provide 2 audio streams over one feed? One coming in over the left channel and the other over the right channel?
If so, what would be required to do this?
ProScan
Software Provider
Ontario, Calif.
After I add support for the Uniden new XT scanners next month, I will be working on suggestions.
Streaming a stereo feed will utilize twice the bandwidth so I'm undecided about the stereo stream. It depends on demand too.
Demand and programming time.
mrscanner2008
Canada
Do you plan to support bc246t? I know its not a recent scanner, but I've bought your software for my 996t and like it very much, so It will be great if I could use it for my bc246T
thanks
Mrscanner2008
ProScan
Software Provider
Ontario, Calif.
thanks
Mrscanner2008
I don't think I will be doing the 246 support as the problem is the 246 is missing a key protocol command GLG so the freqs / tgid's can't be retrieved for logging purposes and the quality of ProScan will be compromised.
mike_s104
Berkeley Co. WV/ Loudoun Co. VA
I just wanted to say thanks for the latest release and for adding the text tag for the Hot Event feature... :)
Also, I came here to ask if it would support the 396XLT. I'm glad I don't have to buy ANOTHER piece of software. :)
ProScan
Software Provider
Ontario, Calif.
Yes... The next release will include the 346XT out about a month and the 396XT two months.
100% of the scanners functions will be incorporated such as Control Channel Data Monitoring, Number Tags Tuning, Jump Mode Tuning, Default Band Coverage Settings, IF Exchange Settings, etc...
mike_s104
will this include the recording/logging of NACs? Do you think if the version for the 396XT is not ready when it first comes out there would be a way to trick the software into thinking it was maybe a 996T or 396T? I understand it might not have all the functionality of the final version with support, but I would like to try.
ProScan
Software Provider
Ontario, Calif.
The development of the BCD396XT and BC346XT support is coming along very nicely and smoother then expected (knock on wood). I will need 396XT testers for a week (at the max) before the official release of ProScan 2.0.
Release date will be 3rd week of April if not sooner and will include both the BCD396XT and BC346XT.
The NAC's will be logged to the history tone column.
Email me to be included in the BCD396XT test.
ProScan
Software Provider
Ontario, Calif.
ProScan 2.0.0 Is Out With BCD39XT And BC346XT Support
ProScan now with BCD396XT and BC346XT scanner support.
ProScan implements near 100% of the scanners capabilities including Jump Tuning, Number Tag Tuning, Control Channel Data Stream Output, etc.
ProScan database layout resembles the scanner's many options in a tabbed format for an overall picture of the scanner menu design.
The 30 day trial / demo is fully functional with no obligation to purchase. Purchase price is $50.00 and includes lifetime updates and running on two computers.
Enjoy.
