ProScan
Software Provider
Ontario, Calif.
Bob
eaf1956
Evansville, IN
Anyone besides me having g web server keep loading the page over and over. If you tap for audio the page reloads and turns audio off. Never did that before.
Sent from my SM-N960U using Tapatalk
ProScan
Software Provider
Ontario, Calif.
ProScan Version 14.5 Just Released.
What's New
  • Fixed - SDS200 Volume and Squelch knobs wasn't going to maximum value.
  • Fixed - BCDx36HP & SDSx00 - Lookup Record Flag From Database wasn't working. Added Record check boxes to the conventional frequencies and TGID grids.
  • Added - Option to change the Month/Day to Day/Month format.
  • Added - Option to show scroll bars on main tabs when some of the controls appear off screen.
ProScan supports the BCT15, BCT15X, BC250D, BC296D, BR330T, BC346XT, BC346XTC, BCD325P2, BCD396T, BCD396XT, BCD436HP, BCD536HP, BC780XLT, BC785D, BC796D, BCD996T, BCD996XT, BCD996P2, SDS100, SDS200, & UBCD3600XLT scanners.
ProScan is the most powerful and feature rich scanner software in the world !!!
Made in the USA
eaf1956
Evansville, IN
What's New
Made in the USA
14 .4 when you check for new version it says up to date
rjdj2000
Gone Cuckoo
Central NY
Been using it since it was made available in the scanner firmware.
Click "Test & Extras" in ProScan, then go to the "Protocol Command" window on the far right and type "MSM,####" (#### = your choice; max appears to be 1000 seconds), then click Send.
Does this work over WiFi or is it only available via direct serial connection? Have tried over WiFi and no luck, just get ERR in the window
buddrousa
It will work WIFI with the BCD535HP or SDS200 with WIFI Bridge or SDS200 Cat5 to your network or using your supplied USB cable, Audio Cable and Line In on your PC.
Just tested with PROSCAN
1 worked with SDS100 USB
2 worked with BCD436HP USB
3 worked with SDS200 WIFI BRIDGE
4 worked with BCD536HP FACTORY WIFI DONGLE.
rjdj2000
Gone Cuckoo
Central NY
Ok well it is the 536 on WiFi and I know dongle is all up to date as I am using it for streaming now. Don't remember what version FW was in scanner but it was recent...
Will just have to keep trying to see if can get it to work
buddrousa
The Command is MSM,0060 will put the SDS or X36 scanner in MASS STORAGE for 60 SECONDS after 60 SECONDS the scanner will AUTO REBOOT.
MSM,0300 will put the scanner in MASS STORAGE for 5 MINUTES after 5 MINUTES the scanner will AUTO REBOOT.
This is all done from the PC no need to touch the scanner.
rjdj2000
Gone Cuckoo
Central NY
Sorry everyone, I was tied up with something and couldn't get back to this. So I checked FW in scanner, it was 01.14.00 so that was first thing I did, updated that. Now when I enter MSM,0120 I get MSM,OK in the window. So I go look at scanner and it is still happily scanning away, no Mass Storage Mode on screen, no reboot. So I guess I have some progress but still more to do. One thing, can all the Source, Web Server and Remote over IP be running when doing this or do they have to be stopped first. So far I have tried both ways with the same result.
rjdj2000
Gone Cuckoo
Central NY
Yes, have been since I installed ProScan years ago when I saw you could do it over WiFi. It is just recently I wanted to try the programming part of it but the main culprit was a outdated FW in scanner as I normally do not update it when it comes out. So now I get the MSM,OK in the response box, but the scanner does not go into Mass Storage Mode and sits scanning away. Just for clarification, this is all over WiFi, no serial connection or USB connection to the scanner.
buddrousa
I forgot you will still have to have the USB cable connected to the Programming PC to read or write to the scanner. I keep forgetting everything on my desk has the USB cables also.
I use Teamviewer to remote in to my PC running PROSCAN when I am at work and make changes to any of my Scanners using the same command.
