ProScan
Software Provider
Ontario, Calif.
Bob
ProScan
Software Provider
Ontario, Calif.
Working right on Android now.
Same as my Firefox version. Works right on two pcs, not on my main one. maybe an extension causing problems. Have to try and track it down. At least working right on Android.
Strick or Standard, same issue.
No big deal I can live with it.
Thanks for the update I was googling the error and came across stuff like this:
. Disable your extensions one by one (especially ad blockers, password managers, or cookie consent bypassers) to find which one causes
. Sometimes cached script states cause mismatched execution contexts. Hard-refresh the page using Ctrl + F5
Enforcer52
Voice Of The Piney Woods
Lake Livingston, TX
I'll play around with extensions one at a time and see. But as long as it works right on Android I'm good with it, since I seldom use web server on this computer to monitor anything. Usually use the phone.
Ctrl+F5 completely wipes out the scanner from the screen.
ProScan
Software Provider
Ontario, Calif.
Folks,
Here is a preview of the upcoming version 24.14 (currently labeled as version 24.13, file version 24.13.2.0).
What's New:
  • Added - View Type: Vertical Mode. Currently supported for HP & SDS scanners only. All other scanners will be done next. Great for using with the Web Server feature.
Screenshot here: ProScan: - Official Software Thread
Download the update here: https://www.proscan.org/ProScan_24_13_2_0.zip
Installation Instructions:
It's not packaged up in a setup file so to install, stop ProScan, then unzip and copy the exe file over your existing file.
dispatchgeek
Control channel goes "brrrrr"
Between the cornfields and the pastures, Michigan.
Folks,
What's New:
Thanks for this Bob. This is helpful on mobile web server and also useful in "Scanner Only" mode on my desktop. I greatly appreciate this.
ProScan
Software Provider
Ontario, Calif.
When I click on recorded traffic in ProScan the program exits. Just started last week still same behavior with latest update. any ideas?
I'm looking into this issue now. I received two emails about it today and one last week, and I've been working with a user today. It appears that Windows Update KB5124010 broke the mp3 playback.
It seems that KB5124010 removed the msmpeg2ac3dec.dll file from the Windows\System32 folder. While ProScan recorder playback doesn't reference that file directly, it uses the mciSendString function in winmm.dll to play back mp3 files.
Current workarounds are:
1. Record in WAV format.
2. Uninstall KB5124010.
Enforcer52
Lake Livingston, TX
Bob,
FYI
KB5124010 appears to only install on Intel cpus' as my Intel N150 mini received that update, but my Asus AMD Ryzen 9 5900XT did not receive that update last week. The Asus machine running ProScan is playing back recordings as expected. I'll load ProScan on the mini and see what it does.
Enforcer52
Lake Livingston, TX
The mini Intel N150 with KB124010, works fine, played back every recording I tried.
So must be something with specific motherboards or cpus, or something else software or driver issue.
ProScan
Software Provider
Ontario, Calif.
Bob,
FYI
I have a Intel CPU, Using Windows 11 Home, 26H2, 26300.9457
It did not install KB5124010
A user with the problem is using 26H2 (build os 26300.9550)
I checked for updates today and it was already current. Strange stuff.
ProScan
Software Provider
Ontario, Calif.
I'm putting together a test file using WMPLib.WindowsMediaPlayer instead of what is currently used for playback which is the mciSendString function in the winmm.dll file. I want to see if it does the same thing.
Enforcer52
Lake Livingston, TX
Nevermind that. It doesn't work when compiled as a 32 bit app.
Microsoft doesn't seem to care what changes to the OS does to non Microsoft software! Never has!
As long as their products work, to heck with everyone else, make them work around the changes.
03msc
RF is RF
The Natural State
Likely because there would be no way for them to test every single program and app that people have made to run on Windows.
