jparks29
John McClane
Yep...can't confuse them with the facts from a higher authority because their minds are already made up.
You also have people who think the gov't shouldn't tell them what to do, and only obey the 'rules' as a courtesy.
The one poster said it was legal to use a part 90 Motorola radio for GMRS if licensed for GMRS. There are many people in the area I live in who do, and reading the FCC rules, they are vague. It is for this reason I don't.
The whole small station rule with 15 watt max, when most Motorola radios have 25 or 45 watts.
What is the real answer to this?
Another part of the GMRS rules says 50 watts on the 7 channels authorized for repeater use, which I have read in a proposal that GMRS repeaters might not be legal if the proposal is passed. There are two GMRS repeaters on the mountain next to me that get more use than the VHF and UHF repeaters right next to them.
I agree 100% with most of what I have read and could care less if the chances of getting caught with a Motorola on GMRS is only 99.9999% that I will not get caught, I won't use or have one if it is not legal.
I don't much care for GMRS anyway, the only reason I have bubble pack GMRS is for EMCOMM since so many are buying and using the moto's for that use as well as ragchewing. Many UHF radios also, that I know is illegal.
As a matter of fact, the local LDS church(s) is pushing for it's members to all get GMRS for emergency's. Not sure if they are talking just bubblepack or not.
73's John
For imformational purposes, i do not own a modded radio, nor have a use for it.
I sit here and see thread after thread about modded radios and i cant help but wonder...... why does the fcc still allow manufacturers to make equipment with the ability to be moded. Obviously they have the ability to keep them from txing outside the ham bands. If its not certified or approved to be anywhere other than ham, why make them?
Just wondering if anyone has any insight on this.
Amen. The manufactures do this because they make money at it. It has gone beyond reason now and should be stopped sooner rather than later.
A lot of older radio models that were capable of this are still floating around. Even if manufacturers and retailers were to end the manufacture and sale of mod-capable radios this calender year, all of those radios still floating around out there will still be there for years to come, until parts for them are no longer available.
This isn't to say that the FCC shouldn't do something about it, just that even if they do, we're still going to see this issue for years to come.
I do agree, however, that at the very least, if they leave wideband receive capability in any particular model, limit the transmit capability to in-band only, with no modification possible.
The problem I have with this argument is that I can't think of a single country that has a 2m range of greater than 144-148 MHz and a 70cm range of greater than 430-450 MHz. If that's true, then why would the manufacturers need to build a radio with a wider range in order to accommodate global amateur radio markets?Well as others have said, the US is not the only market, and the band allocation in other countries are different than here. Instead of having to design multiple boards, one board can be made, and the placement of the jumpers sets the TX range.
In many countries 2m is 144-146 and 70cm is 430-440. That is the worldwide allocation. Some countries have larger bands.
In the USA and Canada 2m is 144-148.
In the USA 70 cm is 420-450 but in Canada it is 430-450.
The international amateur band plans can be found at Regions - International Amateur Radio Union
This is the side i take on this. I dont see why they have to make them to where they can be modded. If they can make a wide band receive radio (my thf6 for example) which will receive hf through 1.3 ghz but even when modified will still only tx from, what, 136-174 i think the spread is for vhf and im not quite sure for uhf. Now if it can be designed to stay within those limits, why not design it to stay within the ham bands only?
I personally cant stand the fact that it is so easy for these radios to fall in the wrong hands. I have been a firefighter for several years and have had to deal with the rogue radios on our system. With the problem of no way to keep unauthorized transmissions. i.e. the 2am wake up from someone playing around and keying the radio over and over.
