DSDPlus DSDPlus 2.444 available
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
Any suggestions editing DsdPlus.frequecies file that won't generate errors.
Commented lines need correcting.
; TIII,H1,14.7,0,454.23215, 454.23215, 0
; Cap+, 2 ,0, 464.35000, 464.35000, 0
; TIII, L2, 3.6, 0, 460.18750, 460.18750, 0
;TIII, 9, 5.4, 0, 217.04375, 217.04375, 0
;TIII, 9, 6.1, 0, 217.10625, 217.10625, 0
Note system number shown in 1R-event log panel is L9, L2, H1 respectively.
Errors I get are invalid network or no data for current site.
TNX
It's definitely barking about your use of H1 and L2 -- you leave the Network model (S/L/H) out of it.
And on your Cap+ line you are missing an element
protocol, networkID, siteNumber, OTAchannelNumber, TXfrequency, RXfrequency, sortOrder
Cap+,2,0,464.35000,464.35000,0
You need 7 elements and you only have six. I know Cap+ does not have a NetworkID. But you need to make one up. Usually it is recommended that if that Cap+ system is in the DB, use the DB sysid as the Network ID.
For example, on this system in my area the SID at the end of the URL is what I use for the Network ID in my Cap+ entries
8755
mtindor
FMP24 PRO USER
Sort of lost me with 'LCN'. Where can I get that?
I have truncated the L and H and the errors change.
TNX
And those errors tell you exactly what the issue was. Before you removed H and L, the error mentioned you had an issue with a missing Network ID. L2 and H1 are not network IDs. Only 2 and 1 are.
Forget what I said about LCN.
Another error is in your Cap+ line (see my last post)
And, like i said, you are going to have to go back and adjust DSDPlus.Networks and DSDPlus.sites if they are not correct.
dave3825
Suffolk County NY
mtindor
FMP24 PRO USER
It wasn't an LCN issue after all. I added all of his commented entries (uncommented of course), and everything passed except the Cap+ entry and the L2/H1 network entries.
dave3825
Suffolk County NY
Anyone notice the window when running FMP24 scanlist on p25 freqs? And no, it's not the bandwidth. Same when 9.5
this,
771.13125 P25 BW=12.5 DELAY=5
771.38125 P25 BW=12.5 DELAY=5
771.86875 P25 BW=12.5 DELAY=5
771.91875 P25 BW=12.5 DELAY=5
770.26875 P25 BW=12.5 DELAY=5
771.14375 P25 BW=12.5 DELAY=5
771.39375 P25 BW=12.5 DELAY=5
771.90625 P25 BW=12.5 DELAY=5
772.03125 P25 BW=12.5 DELAY=5
772.04375 P25 BW=12.5 DELAY=5
772.96875 P25 BW=12.5 DELAY=5
773.21875 P25 BW=12.5 DELAY=5
773.40625 P25 BW=12.5 DELAY=5
773.41875 P25 BW=12.5 DELAY=5
773.46875 P25 BW=12.5 DELAY=5
773.69375 P25 BW=12.5 DELAY=5
774.65625 P25 BW=12.5 DELAY=5
774.66875 P25 BW=12.5 DELAY=5
gives me this,
merlin
DN32su
OK, I'll figure out something for the CAP+ sites (like maybe 1 & 2)
and work on the TIII entries. What throws me is the OTA channel number and how to calculate that.
None of the TIII sites directly reflect that.
I should have no problem editing the network and sites list.
merlin
DN32su
this,
gives me this,
I think that is the bandwidth of the spectrum display set by your bat file. you can change that using 'b' with the spectrum window active or yor bat file. That active grey should encompas the green spectrum or just under that. It will clean up your source audio a bit.
dave3825
Suffolk County NY
Negative. Nothing to do with the selected bandwidth. Did it with 9.5 as well. Circled is what I am talking about.
I set 18 freqs in the scan list, all with P25, and for whatever reason, it thinks 8 are analog.
merlin
DN32su
I see if you don't have a -b setting in FMP24 bat file, it defaults to 12.5 Khz. you can still change that in the active spectrum window.
(Maybe last saved BW)
Like me, looks like you need to edit the scan list or ignore the analog. Likely it will only slow the scan rate.
Are any of these channels analog P25 ? If not, just delete them.
dave3825
Suffolk County NY
Your not understanding. Nothing to do with scan rate or bandwidth.
Setting P25 in the line is supposed to do that, and it's not doing it on all the freqs. And on the ones it does not, it writes RCI where P25 should be, and adds P25, to the end of the line.
Something ain't right...
FMP24.scanlist said;
; FMP24 Scan List
; Entries in this file are scanned when the 'S' key is pressed in FMP24
; Press Esc in FMP24 to exit scanner mode
; Lines with leading semicolons are ignored.
; Use a leading semicolon to "lock out" an entry.
; Use a leading semicolon to add comments/documentation.
; File processing stops if a line containing "<EOF>" is found.
; Entries after the <EOF> line are not processed.
; Line format:
; frequency options description
; Frequency is specified in MHz
; Options:
; Modulation Specifier
; 4 kHz bandwidth digital protocol specifiers:
; iDAS
; NX48
; NXDN48
; NEXEDGE48
; 7.6 kHz bandwidth digital protocol specifiers:
; Dstar
; D-Star
; DMR
; TRBO
; Cap+
; Con+
; TIII
; XPT
; 9.5 kHz bandwidth digital protocol specifiers:
; Fusion
; NX96
; NXDN96
; NEXEDGE96
; P25
; 12.5 kHz bandwidth digital protocol specifiers:
; PV
; ProVoice
; Analog modulation specifiers:
; AM (AM demodulation for airband)
; Anything else, such as "FM" or "Analog" or nothing
; is assumed to be FM modulated analog and defaults to 12.5 kHz bandwidth
; Bandwidth Specifier
; Overrides default bandwidth
; Format: BW=<kHz>
; Valid bandwidth values are 4, 7.6, 9.5, 12.5 and 22
; Delay Specifier
; Keeps FMP24 on a channel / delays resumption of scanning
; for the specified amount of time after a valid signal ends
; Format: DELAY=<seconds>
; Description
; User-supplied channel name/description
; Sample scan list:
118.3 AM BW=12.5 DELAY=2.5 Miami Tower
145.17 DMR DELAY=1.5 N2GKG
162.4 FM WX
454.35 NX48 Acme Inc.
163.8125 P25 BW=12.5 DELAY=5 Feds
FWIF, I have been using the scanlist for a few years the same exact way and never saw this before the last batch of updates.
merlin
DN32su
OK, I am a bit lost with this. Wait for a pro to chime in.
I've attempted to duplicate this several times, using your format posted and your frequencies, as well as active frequencies in my area. Unfortunately I was not able to. Looking at your screenshots it looks like the characters RCI might be from a corrupt file as they do not look like normal characters.
Have you tried replacing the version of FPM24.EXE you are using? Maybe it has something to do with that, I don't know I don't claim to be an expert. But it is something to consider.
merlin
DN32su
Something is amiss. My large P25 sites go back 4 years and each of the recent updates, I check the latest base files and copy what is needed.
The executables and dll's
The control channel frequencys into each of the FMP24.bat files and it just works.
LimaZulu
Digging through my memory now and I do remember I had this issue before. I then had to download the public version and update it to the latest fastlane version for it to start working. Still don't know what is causing the issues but I will try that approach one more time when I have some spare time.
Not sure if that is the right way to start over but it's the only one I can think of. If anyone can point me to a easier way I wouldn't mind to take some advice.
Ok, did that and unfortunately it doesn't help. Not sure what's broken but it's not network related as it behaves the same on different networks, all of then being NXDN48.
merlin
DN32su
You might use FMP24 instead of FMP-CC. also, check and download the latest base files and coppy all the .exe's and dll's to your working directory.
(Thought I had something similar in an old log, but wrong.)
mtindor
FMP24 PRO USER
Does anyone know what this is? I noticed this on last updated also.
Do those occur frequently enough that you could reliably capture raw audio and send it to the author? In many cases these Unhandled PDU cases can be resolved / figured out. But the author would need to be able to reproduce it. Yes, I had some on AEP Harris P25 a while back, at which time I did send them to the author.
mtindor
FMP24 PRO USER
True. If using the version from website, must use FMP. But if using Fastlane, FMP24 has superceded FMP and FMP should never be used on FL versions.
LimaZulu
I am using FMP24 and did downloaded the latest base files
