LB_Scan
Hi
When are they going to fix the ezscan socket error #11001 message on trx 2 scanner. thanks
fxdscon
¯\_(ツ)_/¯
Hi
Whistler themselves are the only ones that could answer that. This is the most current official response from them in the forums on 7/02/24:
Please be patient while we resolve the issue.
Other than that, you can call them at:
Customer Service: 800.531.0004
Also, read post #60 in this thread for a conversation one of our members had with Whistler.
w0nwa
Phoenix Az
The manual updates does it update all the V-folders? when you copy to the scanner?
Machria
Long Island, NY
You must open each V-Folder separately and update each separately.
I don’t have the scanner in front of me to check, I forget exactly, but I think the “Library files” are only stored once on the sd card, and then the v-folders have programming which would mean you only need to copy the Library files “update” once. BUT, you then need to open each v folder in the software and do the “Update Tags, names, control channels…” for each vfolder. Isn’t that correct, or am I wrong and the set of library files are stored in each v-folder also?
Swipesy
Northern Ohio
You are correct
Brunlea
A bit of a GEEK!
Lancashire
Just tried updates via EZScan and the connection has been restored and all appears to be working again :)
Swipesy
Northern Ohio
I don't know about working. I manually updated to #884. When you run EZScan it says Current #884, Available 879??????
