west-pac
- Joined
- Nov 13, 2004
- Messages
- 1,817
- Reaction score
- 916
That map I put up of the repeater sites on SAFE-T, each one of those sites works like Monon. Which is nice, because if you can only get the repeater site (like when using a handheld scanner) you can still get 95%+ of the comms in your 5 county area.
I wish I could get the Lafayette repeater site, but I can get Fowler and that gives me ISP Dist 14 so I'm still good. If you notice Dist 14 isn't on Monon very often, only when they are up around the 192 MM on 65 (which is the north end of Dist 14) that they are on Monon. They are on Fowler a lot, because Fowler is in Dist 14. .... Also White county is on Monon all the time as (I would assume as one of their home sites). Which is great for me because I can't get Lake Shafer or Monticello in Rensselaer. ...Also I can't get Hebron/Kouts but I can get Lowell and Porter Co. is repeated off of Lowell (which is the repeater in that area) so I'm also good to go there. ...Also even though Fowler is not a repeater site Fountain/Warren Co. is on Fowler which lets you hear all the way down to Covington & Attica from here.
You're still wrong. The NPSPAC radio network (the map that you're talking about) has zero connection and affect on the P25 SAFE-T radio system. The only thing they have in common is that they are co-located on the same radio towers.
NPSPAC and SAFE-T is like Coca-Cola and Pepsi. They're 2 different things that don't affect each other.
