New Firmware/PPS Release for G2-G5 Voice Pagers (V2.02 & V0.4.0.39)
exkalibur
York, Ontario
Hello, I'm Brad with Unication Technical Support. New firmware version V2.02 has been undergoing thorough testing and was successfully pre-released to Unication Authorized Dealers a month ago. We are preparing to publicly announce and release new firmware V2.02 later this week and I thought I should share with our RadioReference crowd in advance.
Direct link to the AutoUp site to download the new firmware, PPS and release notes:
https://autoup.unicationusa.com
Still no TETRA I see...
kb8q
Ferndale, MI
I downloaded the new PPS version via the autoup link without any problem. However, when I click the download button on the page for the firmware updater, it downloads a file called CRDOWNLOAD and I can’t figure out how to run it.
I must be missing something.
Not the file name I got when I downloaded through the AutoUp site, FW file was "gseries_voice_firmware_V2.02_20240409.exe"
Unication_Jordan
Unication Representative
Arlington, TX
Unication_Jordan
Arlington, TX
I signed up for the AutoUp service long ago, and then it all stopped. Afterwards, everyone was forced into pestering their dealers, or contacting Unication directly.
Will signing up on this new AutoUp link put me back on the list for future updates like before?
Yes. You can also sign up to be notified when new updates are released at the link below by submitting the form at top of page titled "Stay Updated- Sign Up Here".
www.unication.com/pps-downloads
Unication_Jordan
Arlington, TX
I have two G5s, one 800/VHF and the other 800/UHF. The site requires a serial number so it can provide the best software match. Do I need to obtain separate updates for each unit?
No, Firmware V2.02 supports all models (G2, G3, G4 and G5) of any age in any band split. The serial number used to enter the AutoUp website has no bearing on the Firmware download.
*** Please direct questions/inquiries to info@unication.com or support@unication.com for quickest response. Thank you.
Hit_Factor
Saint Joseph, MI
That's just a temporary file. Could be result of a failed download. Usually those "turn into" the file you intended to download, once the process completes. Be patient, wait for the download to complete. Delete them if they are littering up your hard drive.
trido
Southern In
i sent a log to uni in TW per their request i keep all posted what they find.
Not the answered i was looking for.WOW.
The problem reported by the customer is mainly because the customer set to receive 49 sets of TG, and the TG did not set priority.
Under the trunking system, the more call groups are received, the more likely it is that the beginning of the call or the entire call will be missed.
The busier the system, the more obvious this situation is. This is the Normal phenomena or limitations on trunking system.
Solutions as below.
Solution 1: Reduce the number of TGs received.
Solution 2: Add important TGs to the Priority Talk Group List to ensure that high-priority TGs will not be missed.
I disagree again no issue ver 1.35
Solutions as below.
Makes sense to me, more you try to listen to the less you'll hear.
kb8q
Ferndale, MI
In PPS 4.0, I can’t fiqure out where you enter radio ID’s which used to be entered in the member tab of earlier versions.
Thanks in advance.
Thanks in advance.
If you are using the CPR Manager it is tab C3, if not use tab E2
