Thank youC3, SUID.
Each system has their own list.
Thank youC3, SUID.
ThanksIf you are using the CPR Manager it is tab C3, if not use tab E2
C3, SUID.
Thanks, I figured that out. I’d like to be able to create and upload my own files via import except I haven’t been able to figure out the new CSV format. I support I could create one system and then export it to get the format. Can the Call ID’s be imported?SUID is not the same as the Radio ID, that is under the Individual Call ID column.
Also, @kb8q sorry, I meant C1 if using the CPR Manager. Both places it is entered under the Individual Call ID column.
YesCan the Call ID’s be imported?
I also tried importing a system directly from RadioRef except my login won’t — don’t know why. Same login works in RadioRef and Broadcastify
Radio ID's are entered in the area circled.Thanks, I figured that out. I’d like to be able to create and upload my own files via import except I haven’t been able to figure out the new CSV format. I support I could create one system and then export it to get the format. Can the Call ID’s be imported?
I successfully updated from FW 1.33 to FW 2.02 this morning. I was waiting for firm confirmation from Unication the FW 2.02 was compatible with all sub-models and hardware variants of the G5 before moving to FW 2.xx, and it seems to work without issue.
Perhaps, but then there was noise and doubt from other users that clouded the issue. When I saw the word directly from the manufacturer, I felt more confident that it was applicable and frankly, the V2.x firmware has been revised several times now to work out the bugs (and hopefully not introduce new ones, lol.)They have previously confirmed this, on several platforms including in this thread, that it is compatible for all G2 to G5 pagers. I've been running it since it was announced and seems to be working fine.
New Firmware/PPS Release for G2-G5 Voice Pagers (V2.02 & V0.4.0.39)
no I never have. You should try it, it might helpforums.radioreference.com
Does this recommendation apply to P25 trunking talkgroup also? It seems when importing a system from RR, the Alert mode for each TG is set to none by default. So that means you’d have to manually go through and set each TG?That alert started showing up a few versions ago, it is just a reminder how to best set up the talkgroups.
Understood, thanks. Do you know if that standard setting is able to be changed somewhere?Yes that is correct, RR has nothing to do with Unication, this is a standard setting in the Uncication G series PPS.
I noticed that if I manually add a P25T talkgroup, then the default is Tone/Default Tone. When importing via RR, the Alert Modes are all set to None.
Upgraded PPS and firmware today. No issues.When i import my old config into the new PPS i lose all my P25TGIDs.
And when i read from device i have the same issue too.
Anyone else have this issue ?
Thanks Unication. Your support is top notch. My PPS and firmware updates were a breeze. I'm having no issues with my G5 UHF C model.Hello, I'm Brad with Unication Technical Support. New firmware version V2.02 has been undergoing thorough testing and was successfully pre-released to Unication Authorized Dealers a month ago. We are preparing to publicly announce and release new firmware V2.02 later this week and I thought I should share with our RadioReference crowd in advance.
Direct link to the AutoUp site to download the new firmware, PPS and release notes:
https://autoup.unicationusa.com
That's a google chrome thing. It's a temporary file while your file downloads.I downloaded the new PPS version via the autoup link without any problem. However, when I click the download button on the page for the firmware updater, it downloads a file called CRDOWNLOAD and I can’t figure out how to run it.
I must be missing something.
