New Radio Reference Import Feature For Beta users of 1.40 firmware
lebrunmn
Retired... Get off my lawn!
Hampshire County, WV
Why dont we post what model Pager you have that the new beta 10 is NOT running on?
I know 2 of you have G5 both are VHF models.
Is any one that PPS isnt working using a dif model pager?
Mine are g4 no issue
Also G5 UHF no issue
Beta 10 working fine on my VHF G5... was able to import from RR, write to the G5, and then I reloaded my previous profile with no issues.
kuzikan
Can add that mine seems to work after it has set for some time. Not sure if logging out of pps and computer helped or if the pc going into sleep mode.
Also I programmed G5 VHF and G5 UHF and read back to pps etc multiple times yesterday testing. Everything seemed fine until late in the day when I logged into the pc and pps and it started the errors.
KevinC
The big K
I'm everywhere Focker!
I installed beta 10 on my original computer. I didn't uninstall beta 9 or import any profiles into 10 and was able to do 2 RR imports. We'll see if this holds up.
dhmann1811
I have a G5 VHF and so far, I have not had any issues using the new beta 10 with importing from RR and then programing my pager.
mharris
Bay Area, California
When I hit the big orange "Import Radio Reference" button in the top right corner the entire PPS errors out and closes. Anyone else experience this?
Hit_Factor
Saint Joseph, MI
I switched from my MS Surface Pro to a different machine and the import feature works. Hmmmmmm.......
Probably not platform hardware dependent, something software is likely the culprit. Could be overly protective security software, virus, network, poorly written driver that doesn't share resources. Quite literally it could be thousands of possibilities.
