ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
Magpie
What I did was change from PCM recording to MP3 recording. No errors or 1 kb files :)
MP3 settings Samples p Second: 11025 and Bitrate: 96.
What I did notice is that recorded files are actually 64 kbps instead of 96 kbps. Am I doing something wrong here? Can someone explain? MTIA.
I did some testing this afternoon and found out that for me, MP3 Samples 8000 and Bitrate 64 give the best result. They sound as good as PCM but are much smaller. Will use these settings next week and will report back.
freqseeker
Puget Sound WA.
Web Server
Running the latest ProScan version 11.5 I have a strange problem using it on my old XP computer.
Streaming a BCD996T works fine if the ProScan window is open. If I reduce the window to the tool bar using - the stream side will turn all the controls except the display gray, thus I can't control the radio remotely but the stream still works.
Even more strange is with the ProScan reduced if I open Davis Weatherlink for my home weather station the gray area where the buttons should be now populates with my weather software display. This only happens with ProScan reduced and Weatherlink open.
My new computer Windows 10 running the same scenario as above except using a BCD536HP does not have this problem. Both browsers are Chrome if that matters. The above problem shows up on a PC, android phone, and IPhone.
Any ideas?
Thanks.
Vince.
ProScan
Software Provider
Ontario, Calif.
Any ideas?
Thanks.
Vince.
That's a Windows limitation. Windows can't paint the virtual scanner for sending to a browser when minimized or the screen saver is activated. I can't do anything about that.
freqseeker
Puget Sound WA.
Web Server
OK. I figured it was a windows problem. Is this specific to XP or all Windows? Windows 10 doesn't have the problem for me.
Thank you for the quick reply. Just purchased this software and want to say it is awesome. I wish I had tried it years ago. The remote control has no lag unlike other software, so much in one package. I look forward to learning all the functions.
Vince.
ProScan
Software Provider
Ontario, Calif.
Vince.
I've had a couple of reports of the Virtual Scanner on the browser not rendering correctly when the screensaver on the server side kicked in and when ProScan is minimized(I don't remember what Windows versions). I looked at this issue a couple of times and my google searching determined there wasn't any viable work around. {edit} That's the only issue unable to resolve in ProScan.
ProScan
Software Provider
Ontario, Calif.
I did a quick test just now. Recorder set to 22050, Mono, 96 kbps. WinAmp playback shows recordings are recorded at 22050, Mono, 96 kbps.
ProScan
Software Provider
Ontario, Calif.
ProScan Version 11.6 With DMR / MotoTRBO
What's New In Version 11.6
  • Added - BCD996P2 and BCD325P2 DMR / MotoTRBO Database and History Logging support.
  • Added - Database - Import Sentinel hpd (Favorites) & hpe files.
  • Added - Database - Export Sentinel hpe files.
  • Fixed - History Logging - Copy Selected Rows button click would show an error if scanner type set to BCDx36HP.
  • Fixed - Database - Copy & Paste thousand of channels was slow.
  • Many more small improvements.
ProScan supports the BCT15, BCT15X, BC250D, BC296D, BR330T, BC346XT, BC346XTC, BCD325P2, BCD396T, BCD396XT, BCD436HP (without Favorites editor), BCD536HP (without Favorites editor), BC780XLT, BC785D, BC796D, BCD996T, BCD996XT, & BCD996P2 scanners.
ProScan is the most powerful and feature rich scanner software in this world !!!.
{edit} Title meant to be "With DMR / MotoTRBO support for the BCD325P2 & BCD996P2 scanners"
rwier
Phoenix, AZ
436 Virtual Scanner Feature
While playing with the ProScan Virtual Scanner (436), I was startled when the System Analysis screen showed Zero Signal Strength, Zero Quality, and Zero Activity. I thought something happened to my antenna. Then I looked up at the scanner, and it was showing the GREAT numbers I am used to seeing. I know ProScan is not fully functional for the *36 pair, but the "placeholders" for the three analysis graphs are clearly visible. The graphs are simply not transferring from the scanner. I searched the ProScan Thread for a statement about this *36 feature but came up empty.
Thanks for the continuing development of your fine software!
ProScan
Software Provider
Ontario, Calif.
Did this ever work in ProScan? I'm not sure this was tested before. I'll look at this next. What is the system type?
rwier
Phoenix, AZ
his was my
Don't know if it ever worked, this was my first try and with the 436. Two systems: Motorola Type II SmartZone and Project 25 Phase I.
Correction to post #2469: The Activity graph is transferring. The activity was so low it looked like zero. After switching to the P-25 I TRS the activity picked up and is transferring. Just the Strength and the Quality graphs are dead.
buddrousa
not programming but remote control , audio logging , and logging tg's id's ect
rwier
Phoenix, AZ
Bud, I think you may have been had, lol. I was going to simply post ProScan but I saw Join Date: Dec 2000 and smelled a skunk.
n5ypj
Can scanner audio be streamed with ProScan into a WordPress blog? I'm setting up a blog and if it could be done I'd like to provide audio to select blog followers through the blog.
ProScan
Software Provider
Ontario, Calif.
rwier,
This is fixed. The signal bars weren't displaying properly for the Analyze System Status and RF Power Plot, and Close Call. Email me for the latest file for the fix if you want.
nick223
Ottawa Illinois
I have a question regarding dmr using proscan. I'm running dsd plus and I have all the frequencies in the dsd file twice. Do I need to do the same in the proscan software? First time programming a dmr system into an actual Uniden 996p2 scanner. Any tricks, tips is much appreciated!
Here is the site I'm monitoring site 007 and the Lasalle county TG
http://www.radioreference.com/apps/db/?sid=7547
ProScan
Software Provider
Ontario, Calif.
Clear Talk (DMR 491) Trunking System, Areawide, Illinois - Scanner Frequencies
I don't know why the frequencies twice. That would be more of a scanner or system question versus a ProScan question so perhaps someone that knows would chime in.
{edit} I don't enter the DMR frequencies twice.
