ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
ProScan
Software Provider
Ontario, Calif.
Bob, I just had the program crash on me again - like in the previous version. I had the software up for about five hours, shrunk down to the borderless display. When I came home, I double clicked on the display to bring it up to full size and it crashed. The window flickers, and parts of it are missing. I get a partial popup that displays a cancel button. When I press cancel another cancel button comes up. When I click that, the program closes.
The next time this happens, I'll take a screenshot and post it here. I'm confused as to why this would be happening. I have a pretty robust system with a Intel Core 2 Duo running at 2.8 GHz. I'm running 3 Gig of RAM on Windows XP. I have 821 Gig of free space on the hard drive.
Any thoughts?
So far unable to duplicate but will continue to run various exercises.
I would check that you have al the important Windows updates installed. It probably will not fix it but will eliminate possible cause.
It sounds like some type of memory leak. I'm wondering if anyone else is having this problem.
datainmotion
Hoi Polloi
Indiana
Any thoughts?
I'm sure some have said it, but are you running MS.Net 2.0 or later?
FWIW - Mine runs all day long all week in the truck on a 1.8GHz Core2Duo with no hiccups
ProScan
Software Provider
Ontario, Calif.
I'm sure he is using the .net framework 2.0. ProScan won't even start without it.
The .net framework 1.0, 1.1, 2.0, 3.0, 3.5 versions are designed to co-exist and the higher number does not replace the lower number so if someone had only 3.5 they will still need 2.0 fro ProScan to work
datainmotion, Are you using XP?
jjudson
Northwestern North Carolina
BTW, to all who are reading this thread: What I'm experiencing seems to be an isolated problem. I've taken this up with Bob on the side. It's also only a minor annoyance and doesn't really affect the use of the program - which is a GREAT piece of software.
Bob has been very quick to respond and work with me on this issue. He has very much demonstrated to me that he really cares about our experience with his programming - even for minor annoyances.
...Just thought you should know.
mrkelso
NNJ
Any thoughts?
Do you have Hybernate turned off on you pc? IN you other setting do you have an energy scheme set up to where the monitor or drives go off after a certain time? How much I would start by raising that 3 gigs to 4 and looking at the power settings real close.
jjudson
Hibernate is turned off. The only energy scheme I have active is the hard drives shut down after 30 minutes. As far as memory, I actually have 4 gig in the machine. XP only recognizes three. Generally, I will have over 2 gig available at any one time.
mrkelso
NNJ
Hmmm My R key seems to be sticking................ Try changing your hard drive setting to not turn off and see what that does.
mrkelso
NNJ
I have been switching back and forth with the windows with no problems at all.
Running on a Dell Laptop the older inspiron B130
webstar22
RenfrewCountyScanner.com
Ontario, Canada
Feature Request:
This just came to me while I was in the shower. RR.com has some restrictions on what you can stream so i ask if the followiing is possible to add sometype of mute flag to TG's and freqs.
This is my line of thinking, you want to hear yourself what is going on but due to the nature of what is happening you don't think it's a good idea to stream that TG so you flag it with a mute which could be like a record flag.
You would still hear the audio and the audio would still record but the outputs to ScanCast will be muted so they don't hear the audio.
Could this work?
