ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
ProScan
Software Provider
Ontario, Calif.
BCD996XT and BCT15X support Ready For Testing
ProScan BCD996XT / BCT15X 1st Test Version 3.9.0
http://www.proscan.org/ProScan.zip
This assumes that ProScan is installed on your computer and contains the executable only. Extract and copy this .exe over the original .exe.
Post the bugs on the ProScan message board or email them to me.
BCT15X Questions:
How does the Mute / CC knob work? For muting the scanner; Is it a knob press? For Activating CC; Is it a double press or hold down the knob? Same question with the light and state knob?
Is there "Military" in the Service Search menu?
Menu - Search for . . . Service Search
mrkelso
NNJ
Yes on the BCT15X the Sql knob pushes in to mute alert and if you hold it long enough it turns on a hold on the mute alert
mrkelso
NNJ
I light knob works like this .each push changed color intensity and changes colors. As far as the state goes i don't know yet
mrkelso
NNJ
Public Safety
News
Ham Radio
Marine
Railroad
Air
CB Radio
FRS/GMRS/MURS
Racing
FM BROADCAST
Special
THis is off of my 996XT
mike_s104
Berkeley Co. WV/ Loudoun Co. VA
Only for testing. There could be a problem with ProScan. We just don't know but we have to narrow down the problem.
Troubleshooting steps tonight:
1. before I wasted any more of your time, I rebooted the PC. issue remained.
2. tried different USB-to-serial adapter on another PC with (Windows 7 64bit) issue remained.
3. downgraded firmware to 1.07.00. issue remained on original PC.
4. tried v3.9.0. issue remained.
5. tried fresh install. issue remained.
6. tried fresh install of 2.1.0. issue remained
7. tried update from fresh 2.1.0 install to 2.9.4. issue remained.
The Windows XP PC that has had the software running has not had any Windows updates or anything install in months. I don't know what's going on. So, it does it when I back it down to version 1.07.00 firmware. Weird. I'm not sure what firmware version was on the scanner, but I know this was the first time I upgraded it. Could be a problem with me or the scanner. :)
ProScan
Software Provider
Ontario, Calif.
ProScan BCD996XT / BCT15X 2nd Test Version 3.9.1
This is a test file and requires ProScan installed on your computer. Extract and copy the .exe over the original .exe.
  • Fixed - Adding trunking channels
  • Fixed - Pri problem
  • Fixed (Hopefully) - "Hold / Resume" button
ProScan
Software Provider
Ontario, Calif.
ProScan BCD996XT / BCT15X 3rd Test Version 3.9.2
This file contains the executable only and is intended as a test. ProScan needs to be installed on your computer. Extract and copy the .exe over the original .exe.
  • Added - BCT15X - Bear Tracker parameters added to the database
  • Added - BCT15X - States added to the database
  • Fixed - XT series scanners - Jump was going into program mode
ProScan
Software Provider
Ontario, Calif.
Link is for a screen capture of what ProScan does with scanning the systems that it hangs on.
YouTube - 396XT Hanging With ProScan
Good video. What they say "A picture is like a thousand words" is true.
I see the control channel output is on. Go to the CC Data tab and hit the stop button.
While the CC output data is a nice Uniden addition, it's not really good to keep it on all the time as it streams tremendous amounts of data bogging down the serial port.
mike_s104
That took care of it. "start" turned to "stop" only for a slit second but I got it. Thanks! I guess it is a setting on the scanner when started? If so, that would explain for happening on different PCs.
I used Campasia from TechSmith for the video. Great program.
ProScan
Software Provider
Ontario, Calif.
Will you be making a feature to program radio ID's with the XT scanners??
The UID's are programed the same as talk group ID's except the UID's needs the letter "i" before the UID.
Did this answer it or are you asking about something else.
Robert721
Klein, TX
help with ProScan and Radio Ref site
is there a tutorial for using ProScan with the Radio Ref site. I am trying to program a 996XT
ProScan
Software Provider
Ontario, Calif.
No tutorials, If I did them, ProScan would still be on version 1 or 2. After you get the hang of something, they are prety much useless anyways. I try to make the program as user friendly as can be.
Steps importing from from RR (short version).
1) A database file needs to be open
2) Go to the menu Import and then to RadioReference Web (or CD)
3) Enter your RR login info and click the Connect button.
4) Choose Country, State, etc..
5) Select a system
6) Click on the Retrieve Data button next to the system.
7) Review the systems, channels, tgids, freqs in the tree on the left.
8) Click the import button
