ProScan
Software Provider
Ontario, Calif.
I can remove 1 duplicate using the "find next same" and the program will crash, you loose all your work and need to start over.
I would like to fix this problem. I can't duplicate. So to fix it, I need an email with someone who is experiencing this problem. Email me with the database file. I asked before for an email in post 2818 and 2828 and no one responded
medic29
Champaign, IL
Bob,
I emailed you last September about this issue. You told me then you couldn't duplicate it. This evening I sent you a video file showing my desktop and showing it happening. It is very repeatable.
ProScan
Software Provider
Ontario, Calif.
Bob,
Thank you, I'll start this today.
nyair1
All devices are shown. From what i had read on HP forums it looks like you have to have a 4 pin 1/8" cable to be able to use that jack. Its a combo headphones/mic input jack. It probably isnt seeing my cable plugged in because it is only a 3 pin cable. I guess im the only one trying to do this on a newer style laptop with only a single input.
Sent from my SM-G920V using Tapatalk
Anyone else having problems trying to record audio with a laptop only having a headphone/mic jack?? Its a HP model with windows 10.
medic29
Champaign, IL
I have no problem recording audio from my BCD996P2 with my laptop and ProScan. Actually, I have used this to identify numerous talk group IDs recently.
nyair1
Do you have a mic input and headphone jack or just one combo jack?
nyair1
Just the one jack used for everything
Sent from my SAMSUNG-SM-G930A using Tapatalk
Ok what model is your computer? I just picked up this hp last week. Was doing some reading on hp forums about using that jack. Said you needed a 4 pin style jack in order to get the computer to see whats plugged in. Cable has 2 jacks off it. One is for mic input and one for headphone input. Ive been playing around with it last nite and cant always get that mic jack to see whats plugged in it. Im not sure if the jack is possibly bad??
medic29
Champaign, IL
Mine just has the regular 1/8" audio jack, like a headphone jack. I use a standard Mono jumper cord between the scanner and laptop. You may try using a different cord.
medic29
Champaign, IL
Yeah, I just searched and read that forum. Just use a regular Mono audio cable and it will work just fine.
nyair1
Are you just running one radio? Im going to try and mess with it again tonite
medic29
Champaign, IL
Yes, just connecting one scanner to one computer.
n5ypj
How to record BC536HP audio through USB port
Hi,
I just made a few equipment moves in the shack and would now like to record audio from my BCD536HP over the radio / PC USB connections. I'm running the latest edition ProScan and currently using the mobo's built in sound card.
Any help appreciated. Thanks for taking the time to read this! 73
Richard
