ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
gillham
Southern NH
I just built up a new computer, and deactivated my old ProScan license on the old computer.. But now I'm having trouble finding the e-mail with the key.
Could someone tell me what e-mail address it comes from?
I did a search on my Inbox for ProScan and "proscan.org", no-go.
TIA
eaf1956
Evansville, IN
TIA
Bob can send you the info but he only does it on certain days so don't be in a hurry about it. Just send him an email.
ProScan
Software Provider
Ontario, Calif.
TIA
Receipt contains the key and came from register@proscan.org. Check your Spam folder.
Lost keys are handled by email and sent on Mondays by close of business. Provide identifiable info such as email address used time of purchase or date of purchase and name.
N5XTC
Hampton, Virginia
I want to purchase proscan as i used the trial and loved it. but, the only feed i listen is OHio Lake County on the MARCS system. is that feed still on proscan? if not, i dont have any use for it. would like to know this before i purchase. thanks
ProScan
Software Provider
Ontario, Calif.
Use the free ProScan Client if you just want to listen to RSOIP feeds. The full ProScan is for using with a supported scanner connected to the same machine running ProScan.
Also, I don't run the feeds so I have no control if any of the feeds disappears some point in the future.
beachside
Melbourne
When using Proscan with my BCSD-536HP scanner all the P25 Digital traffic is muffled. I have tried everything. Any idea's?
How are you getting the audio from the scanner? The 536 doesn't have a line out and using the speaker output is a bit complicated as it needs some interfacing components, like a audio transformer. The 536 is unique like this.
ProScan
Software Provider
Ontario, Calif.
Is this happening with the scanner speaker or computer speakers? Have you tried non P25 systems? If happening only on computer speakers then I would turn down the volume on the scanner as you may be overdriving the sound card.
mike_s104
Berkeley Co. WV/ Loudoun Co. VA
Also adjust the audio on the sound device settings
Sent from my SM-G930V using Tapatalk
Natrona Heights, Pennsylvania
The find duplicate utility isn't working right. If you click "find next same item" when there are multiples of a frequency and you get to the last of the duplicates, clicking "find previous same item" won't go back to previous item--it just does nothing. You have to exit the duplicate finder and start over.
Also, forcing conventional and trunked freqs into separate categories is a PITA. I have a list of freqs found during a band search that are a mix of conventional and trunked. It would be nice to trim out everything from that list that is already known, but I can't do that because of the limitation.
It would also be useful if the duplicate finder ignored duplicates more than X number of miles apart.
Hi Bob, I have the same problem with my BCD996P2. I can remove 1 duplicate using the "find next same" and the program will crash, you loose all your work and need to start over. I found if you get frequencies in order as to have 453.1000 x 4 lined up you can manually remove them by just using the "find next" and continue. It seems to crash more if it jumps between a few different systems.
Thanks for all your hark work!!
nick223
Ottawa Illinois
Is there anyway to enhance the 996p2 UBS programming cable settings to work with proscan better? No matter what computer I'm using it always takes me about 30 mins and a few restarts of proscan or the computer to get proscan communicating with the 996p2. Every time I open proscan it always says the comport is already in use or I go refresh the comports and half the time it's in the drop down list and it doesn't work or I go auto detect and the port says it's being used by another program or this program and still won't work. But when I go into the device status all the time the Uniden cable is always recognized. I didn't know if there was a fixed it just annoying
ProScan
Software Provider
Ontario, Calif.
Bugs are best by email (Same with suggestions). That way I can ask additional questions and send out test files until fixed and you get the latest file. Advise on the version number. Also send the database file and how you are using the Find Duplicates(Where and Item).
ProScan
Software Provider
Ontario, Calif.
Nothing can be done about that in the software using a BCD996P2. It's more of a driver issue. The rear port is recommended on the BCD996P2. If using the front port then a power cycle of the BCD996P2 is needed to reestablish the communications.
