ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
ofd8001
Louisville, KY
I'm still learning ProScan and NXDN so bear with me please.
I downloaded a conventional system listed as having some NXDN frequencies (Franklin County KY). RR database says the FD dispatch frequency is NXDN RAN 21. When I imported, I got DCS 21.
Will there be an issue that way - DCS versus RAN?
dave3825
Suffolk County NY
Bob, similar problem also. I had some rr data saved in Excel and when I used the get clipboard, it substituted the ran with DCS.
If you want to try, copy this into an xlsx file.
Code:
451.95000 46 RAN Tappan Zee Constructors
452.07500 46 RAN Tappan Zee Constructors
ProScan
Software Provider
Ontario, Calif.
It's fixed. Will be in the next version
BigWonton
Cleveland, OH
Next version of ProScan, release probably next week or the week after will contain the following:
  • Added - Web Server Metadata Delay option now delays the Display too so the audio and data appear in sync.
  • Thanks for this update - it makes it so much easier to follow conversations and match them up with UIDs being displayed.
    One small thing I noticed was that the alert light on the display doesn't seem to be delayed - is that on purpose or is it possible to have that delayed with the display data?
phask
zanesville
Are UID in the record strem? I know the latency was an issue - but IF this will fix it I can go back to using Proscan for UID discovery as well.
ProScan
Software Provider
Ontario, Calif.
That's on purpose. Lights are part of the panel. If the panel was delayed then when the user presses a key, it will not show in the pressed state(shadow effect) immediately and the user won't have positive feedback that the key was actually pressed.
{edit} I should of said keypad is part of the panel along with the lights so I have to delay both or none. I chose none so the user will have positive feedback when a key was pressed.
ProScan
Software Provider
Ontario, Calif.
I don't recommend UID's in the recorder filename as many UID's will be on a single talk group and the UID's can arrive late or not at all.
kb7gjy
Bonners Ferry, Idaho
Ran into a problem programming with Proscan.
USB Mass Storage mode
I can read the programming from the 536, No issues.
Modify the programming in Proscan, No issues
When I go to write to the 536, it shows the scanner. The 536 is highlighted and I click OK. It then gives me the spinning (busy mouse pointer) for a couple seconds and then closes the write to scanner window.
When I go to see if the programming took, the updated programing is not there.
When I do it with Sentinel, it works no problem.
Ideas?
WX4JCW
Stow, Ohio
Ideas?
im thinking its the SD Card, it may have a problem
W4KRR
Coconut Creek
Have upgraded ProScan to latest version to get NXDN support of the BCD436HP.
On my NXDN system, for some reason, the system type has changed itself from "NXDN Trunk" to "ON', and it won't let me change it back. As a result, my LCN's are gone, along with some other data.
Also, the "Dept/Sites Quick Key Status" does not retain what I have checked or unchecked.
Looks like I am going to have to start from scratch to correct this mess. :evil:
W4KRR
Coconut Creek
This was fixed about an hour ago. Will be in the next release.
Okay, very good. I was able to recover from my issue by creating a new NXDN Trunked system, and then use the copy feature to copy all the Sites, Departments, etc. to the newly created system. (Thanks for having the "Copy Selected Nodes" feature)!
One more thing: I can read from and write to the scanner with no issue, however there is no progress bar, or anything to indicate if the process is completed or not. Knowing the upload/download progress would be a big help to avoid disconnecting the cable too soon.
ProScan
Software Provider
Ontario, Calif.
ProScan Version 12.12
What's New In Version 12.12
  • Fixed - Importing from RRDB and clipboard NXDN, RAN tones was importing as DCS tones on conventional frequencies.
  • Fixed - BCDx36HP Favorites Editor - Department and Dept / Site Quick Key Status broke.
ProScan supports the BCT15, BCT15X, BC250D, BC296D, BR330T, BC346XT, BC346XTC, BCD325P2, BCD396T, BCD396XT, BCD436HP, BCD536HP, BC780XLT, BC785D, BC796D, BCD996T, BCD996XT, & BCD996P2 scanners.
ProScan is the most powerful and feature rich scanner software in the world !!!
Made in the USA
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
On 12.11 - when editing the location settings for a site/department/etc., I cannot enter the decimal point in the "range" editbox. For example if I want to enter 12.5, and I type '1' '2' '.' '5', I see 125.
Going to Google Maps and moving the circle on the map then hitting Update fills in the proper value.
