ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
randybcd396t
Los Angeles
I want add my name to the list of people who think ProScan is a great deal - no promo codes needed.
I've been using ProScan for almost 10 years. It's supported my BCD396T, BCD396XT, HomePatrol and BCD436HP all with FREE upgrades for the new scanner models. Soon I'll have the SDS100. Probably another free upgrade, but worth it even if there is a fee.
Randy
ProScan
Software Provider
Ontario, Calif.
As you may of heard by now, Uniden is offering BCDx36HP NXDN support.https://forums.radioreference.com/u...p-firmware-1-14-00-available.html#post2904825
Next version of ProScan, release probably next week or the week after will contain the following:
  • Added - Web Server Metadata Delay option now delays the Display too so the audio and data appear in sync.
  • Added - Recording Files When Deleted Send To Recycle Bin (100 times slower when checked) option.
  • Added - BCD436HP & BCD536HP NXDN support (RAN and Area in conventional programming).
  • Added - BCD436HP & BCD536HP Icom IDAS support.
  • Fixed - Database Quick Key Status grid wasn't scrolling far enough to show all the systems.
  • Fixed - Web Server - When serving Folders & Files, if thousands of files, server slow to respond.
STS100 scanner support will be started after next release.
jonwienke
More Info Coming Soon!
VA
The Tone column isn't currently correctly sorting RAN entries. Will that be fixed in the new release?
ProScan
Software Provider
Ontario, Calif.
ProScan Version 12.9
What's New In Version 12.9
  • Added - Recording Option - Recording Files When Deleted Send To Recycle Bin (100 times slower when checked).
  • Added - BCD436HP & BCD536HP NXDN support.
  • Fixed - Web Server - Server slow to respond when serving folders & files if thousands of files.
  • Many more small improvements.
ProScan supports the BCT15, BCT15X, BC250D, BC296D, BR330T, BC346XT, BC346XTC, BCD325P2, BCD396T, BCD396XT, BCD436HP, BCD536HP, BC780XLT, BC785D, BC796D, BCD996T, BCD996XT, & BCD996P2 scanners.
ProScan is the most powerful and feature rich scanner software in the world !!!
Made in the USA
dave3825
Suffolk County NY
I just woke up, so I might be missing it, but when programming conventional NXDN, the only choices are P25 Nac and Color Code. How do you set Ran and how do you set it to search the Ran?
Going to make the coffee now.
ProScan
Software Provider
Ontario, Calif.
That would be the Digital Code Option Set NEXEDGE RAN & SET IDAS Area. Didn't know about that. Working on it now.
ProScan
Software Provider
Ontario, Calif.
Fixed - NXDN Conventional channels Audio Type now includes NEXEDGE RAN & IDAS Area.
Download ver. 12.10
jasonhouk
Uniden AlphaMan
Uniden Representative
Marion, Ohio
Importing a NXDN Trunk from RR the LCN numbers are not corresponding to RR CHID?
Houk
