ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
ProScan
Software Provider
Ontario, Calif.
Can't find Test & Extra tab or any of the files.
The Test & Extra tab is the far right tab.
You can't find the VirtualStore folder or the files inside?
Is there a video for this or more detailed instructions?
Negative.
In every other scanner, ham and music programs I own, transferring files from one computer to another is very easy.
If the program was elevated to Admin or the program is installed in another folder besides Program Files (x86) then the program generated data files will be in the ProScan folder. That's the way Windows work on 64 bit systems on non elevated to Admin programs in the Program Files (x86) folder.
{edit} Thanks smason for the screenshot.
ki6bu
Mesa AZ
I'm 3 days new with Proscan - demo, looks really slick, I'm trying to like it. Now for a really dumb question, mind you - like someone else stated, I'm drinking this with a fire hose. Radio - BCD436HP, I bring up the radio menu by clicking on the "MENU" button on the pictured radio, I can scroll thru the menu options with my mouse wheel, -how the heck do you select and item in the menu? On the radio of course you just press down on the knob on the top.
I have clicked and pressed every button on that screen, but the right one. I've been at this for over 2 hours.
Whats the secret?
OK, I just figured it out, I guess you have to post the question and then right after things come to you.
" E/YES" button
ProScan
Software Provider
Ontario, Calif.
Whats the secret?
" E/YES" button
Double clicking the big knob will also do it. A single click will get the focus so it could be turned CCW or CW with the mouse or keyboard.
johnmac
Westminster, Ma
Web Server
In light of changes at Broadcastify, I am experimenting with the web server portion of ProScan. Is there any way to allow the audio to start when the web page loads?
Also, what folder is the web page located in or is created on the fly when I access the web server. I see the css style sheets, but nothing else.
Thanks for any thoughts or suggestions.
John
johnmac
Westminster, Ma
John
Just a follow-up. The web server either freezes or the audio only stays active for a few minutes and then the audio needs to be re-started.
jonwienke
More Info Coming Soon!
VA
I'm seeing a bug where Search With Scan transmissions are not being recorded. The audio plays, but no recording shows up on the recording log.
ProScan
Software Provider
Ontario, Calif.
Negative. Must press the Play button.
John
The web page is generated dynamically within ProScan. No file.
ProScan
Software Provider
Ontario, Calif.
I'll look at it before the next version is released. It it's not fixed in next version, email the bug report so I can email you back with test files until fixed.
https://www.proscan.org/bugs_suggestions.html
ProScan
Software Provider
Ontario, Calif.
I'm unable to duplicate.
Is the Activity indicator around the display showing?
Are the transmissions logging to the History Logging grid?
Is it recording only Search or only Scan? If Scan, is it only a certain system type?
jonwienke
VA
All transmissions from other systems, both digital and analog, seem to be recorded normally. The transmission audio always plays normally.
But intermittently there is no activity in the recording grid during a Search With Scan / Close Call Hits transmission. No new row is created, nothing is highlighted red as normally seen while recording is active. If there are several successive transmissions, the first one is the most likely to be recorded, and reply transmissions are more likely to not be recorded.
I noticed this on air band. I don't usually listen to planes, but one flew overhead close enough to generate a Close Call hit, and then I got a bunch of traffic--mostly clusters of short transmissions. At first I thought it was because the option to delete <2 second transmissions was turned on, but that box is unchecked. I also tried toggling the skip silence box, but that didn't change anything either.
I never noticed this before upgrading to 1.16.00. is it possible that the scanner firmware could stream audio to Proscan, but not trigger recording, because of a firmware bug?
One other thought, I typically have 7000-9000 recordings in the Recorder grid (Auto Delete 5 days). It is common for a transmission to start, and then the new row in the Recorder grid to pop up a few seconds later. But sometimes the new row is populated almost immediately. Is it possible the grid is being overloaded because it has too many rows? My laptop isn't a gaming superbeast, but it does have a reasonably fast CPU and 16GB of RAM, Windows 10 64-bit.
jonwienke
VA
I'm currently running 1.16.04 that seems to fix the buzz after digital transmission in stream bug, and I'm still missing 50% or more of Search With Scan / Close Call Hits traffic in the Recording tab. I just heard 3 or 4 transmissions from a nearby business, and none of them got recorded.
