ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
jonwienke
More Info Coming Soon!
VA
There's no special character in the filename, and all other systems and departments record 100%.
Close Call Hits is the only system that has trouble recording.
ProScan
Software Provider
Ontario, Calif.
Perhaps the recording path & filename is exceeding the limit of 260 characters. For a test, I would modify the custom recording folders and filenames format specifiers.
jonwienke
VA
Nope.
Here's a sample file name for Close Call Hits, which has the intermittent problem:
D:\Media\ScannerAudio\2018-04-26\Search with Scan\Close Call Hits _ _ 18-59-34-461.mp3
And here is a sample filename from another system, which records correctly 100% of the time as far as I can tell:
D:\Media\ScannerAudio\2018-04-27\Chambersburg Area School District - Clarks Knob\Transportation _ School Buses 5 _ 07-45-41-450.mp3
If the number of characters was an issue, the Chambersburg system would have more issues than Close Call Hits.
Given that I first noticed the problem after upgrading to firmware 1.16, is it possible that it could be a firmware issue somehow? Is ProScan looking for data that normally accompanies audio data to start recording (like the channel / frequency / system metadata), such that if that data was not sent or malformatted, that recording would not be started, even if audio data is sent and streamed normally?
ProScan
Software Provider
Ontario, Calif.
Nope.
The absolute best and most efficient way to fix bugs is by email. I always send test files until fixed or at least an ideal of what's going on.
https://www.proscan.org/bugs_suggestions.html
RF23
Sorting Data
If you use Proscan to sort your logged data it is fast and accurate.
However, if you export this logged data to Excel and use it to sort by frequency it will not sort the frequency/1 or frequency/2 data column (frequency + slot numbers in DMR) correctly with respect to the other frequencies.
I suggest using Proscan to sort in these cases then export the data.
iMONITOR
Silent Key
S.E. Michigan
Dual monitiors and cool display tricks!
I've been playing around with some of the 'View' options in ProScan, and different ways to take full advantage of dual monitors.
I'm running ProScan's View mode as 'Scanner Only (Detached Window). I'm displaying the scanner only on one monitor with resolution set at 1920 x 1080 and a Scale and layout set at 175%. This makes the scanner itself really big (like it would if the monitor was set to a lower resolution and I can read it at a quick glance, even from across the room!
Then I drag the History Log over to the other monitor with resolution also set at 1920 x 1080, but the Scale and layout set at 100%. This makes the log info smaller so it will fit the screen and show all of the information, as if the resolution was set higher!
ProScan
Software Provider
Ontario, Calif.
Nothing really can be done in the software for this type of issue.
iMONITOR
Silent Key
S.E. Michigan
You misunderstood. It's not an issue, it's a feature! I'm complimenting your software for having the ability to do this.
That's the way I wanted it. I can set it so it's the same on both monitors, but I actually wanted the scanner really big. But I wanted the log smaller, so I can view all the data. Now I have the best of both worlds.
ProScan
Software Provider
Ontario, Calif.
Okay very good to hear, I was worried for a minute.
roccuschaser
Maine
Enjoying Proscan very much! I have my 996P2 connected to it and it is helping me understand this scanner better, and learning new things with this software as I go. Soon I will be connecting my BCT15X to it as well. The only thing if I may suggest for future upgrade would be to add another column to the data base page with rows for comments or notes for each frequency programmed.. this would just be handy to have. Thanks for a nice scanner package!!!
AC0RV
Park Hills, MO
Can someone in the right direction. So I record the traffic via WIFI from my 536HP ?
Also is there a manual for the PROSCAN ?
Big Thanks.-
ProScan
Software Provider
Ontario, Calif.
Big Thanks.-
The manual is accessed in the Support menu.
For recording from the Wi-Fi. Setup steps are:
1. Setup Wi-Fi audio
a. Go to the Audio Control - Recorder tab
b. Select URL for the Input Sound Device
c. Click the URL Setup button
d. Enter the scanner IP Address using the format in the example below the the IP Address box
e. Click Connect
f. If connected, no errors will show and the Bytes will increment
2. Setup Wi-Fi data
a. Go to the Comm. Port menu
b. Select URL
e. Click Connect
3. Go to the Recorder tab and turn on the recorder
a. Go to the Options - Recording to change options
ProScan
Software Provider
Ontario, Calif.
ProScan Version 12.13
What's New In Version 12.13
  • Fixed - Location Range in Favorites Editor wasn't allowing decimal point.
  • Fixed - Importing Unit ID's from Clipboard to BCDX36HP wasn't working.
  • Fixed - Importing from the RRDB - NXDN IDAS Type D TGID's wasn't formatted correctly.
  • Fixed - Web Server intermittent exemptions (errors).
  • Fixed - BCD536HP Wi-Fi - Source Client streaming to Broadcastify / Icecast / Shoutcast servers will now stay connected if the Wi-Fi goes down or glitches.
  • Added - BCDX36HP Favorites Editor message when finished reading & writing to the scanner.
  • Added - BCDX36HP Favorites Editor 'Monitor' parameter.
  • Added - History Import to BCDX36HP Favorites.
  • Many more small improvements.
ProScan supports the BCT15, BCT15X, BC250D, BC296D, BR330T, BC346XT, BC346XTC, BCD325P2, BCD396T, BCD396XT, BCD436HP, BCD536HP, BC780XLT, BC785D, BC796D, BCD996T, BCD996XT, & BCD996P2 scanners.
ProScan is the most powerful and feature rich scanner software in the world !!!
Made in the USA
