ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
BBang
Smiths Grove Ky.
Click database
Click Import
Choose RR ( RR Subscription Required)
It opens small box that states: A Datbase File Must Be Open
Click On Database Menu And Click New Or Open
Stops there with no option to Log In or submit User and Password.
Btandon
gcopter1
Winter Park, Florida
The port number is 554 as specified by the RTSP protocol specs in RFC 2326.
That's the scanner or outbound port. The inbound port to ProScan changes on each connection.
{edit} I don't think you want to find out what ports are in use but rather what is blocking the TCP traffic on port 554 to the scanner.
I used the resource monitor in Windows 7, there's nothing using TCP port 554.
ProScan
Software Provider
Ontario, Calif.
Click database
Click Import
Btandon
Did you click on the Database menu then clicked on New? After that, go to the RRDB Import and log in.
{edit} You missed step 1.
BBang
Smiths Grove Ky.
Let me ask a question. I have the working full 30 day trial version running. I plan on purchaseing the proscan but just haven't yet. Will that make a difference??
Brandon
ProScan
Software Provider
Ontario, Calif.
Brandon
The 30 day trial is fully functional just like the licensed copy. That's on the ProScan main web page.
Did you do as I advised in the email which is "I see you hit the Cancel button. Don't do that. Type in a Filename and click the Save button."
BBang
Smiths Grove Ky.
I even downloaded them form RR to my desktop, Opened Proscan, clicked database, Clicked open, looked in desktop, the folder I saved them in called Proscan 1, and it says that I'm missing a dll. file ext.
I cant find the 500 TCP port you referenced earlier!! I just think I'm not connecting to RR is the problem but don't know why. FYI I'm on a mac and running windows through bootcamp. I use it for my auto inventor and it works great. Just like having a PC. AGAIN I appreciate this more than you know!!
BBang
Smiths Grove Ky.
Device manager says my multimedia controller has an issue. Would that be the prob.?
I don't have a problem listening to video or music though! Like You Tube.
ProScan
Software Provider
Ontario, Calif.
A missing dll message indicates you didn't install ProScan correctly.
I never referenced port 500. Just port 554 which is used for the BCD536HP Wi-Fi audio which isn't the case here.
ProScan
Software Provider
Ontario, Calif.
Negative.
You're all over the place which makes it difficult to guild you through the problem. Just focus on the original problem and follow the steps I posted earlier.
Type in a Filename and click the Save button then try to import from the RRDB.
{edit} Perhaps you choose a filename by clicking on an existing file which overwrote the file with a ProScan database file. If that's the case, you may have to download and install ProScan again. No need to uninstall ProScan first.
BBang
Smiths Grove Ky.
You are the MAN Bro.. Did what you said in the email then followed the steps in the previous post and WALA, I'm in!!! if you was local I would buy you whatever non-alcoholic drink you wanted!! LOL
Thank You very much and I hope I wasn't to much of a inconvenience.
Thanks,
Brandon (BBang)
BBang
Smiths Grove Ky.
Ok, I bet you knew I would be back! Do I want to up load my current programing and then add the RR import to it before I export to my unit? I guess what I'm asking is, if I export will it erase or overwrite what is currently on my scanner or will it just add it to it?
Brandon
ProScan
Software Provider
Ontario, Calif.
Brandon
Import from RRDB first then upload to the scanner. Please use the correct terminology so it doesn't add to the confusion. Upload to scanner, not export to the scanner.
Choose the appropriate upload option in the Upload window. Options are self explanatory. Are they not?
{edit} After you upload the new systems, you may want to download from the scanner to the ProScan database so the database will be an exact copy of the systems in the scanner.
oracavon
Somewhere out west
can you run proscan on two units at the same time. I have another scanner coming and want to run both with each having there own proscan running?
Yup, I'm doing that. Below is from the user manual, available at https://www.proscan.org/ProScan_Manual.pdf:
Can I run multiple copies of ProScan on one computer?
Yes. Many instances of ProScan can run on the same computer. 1) Copy and paste an existing folder and rename the new folder.
2) Run from the new folder and change the options specific to that instance.
BBang
Smiths Grove Ky.
Ok, I got a folder named current programing. I also have a folder called playing around. I done this to learn how to enter all my info through proscan instead of the manual entry and to just tinker and learn. I didn't want to mess up the program that I knew was right! Now I have a new system completely set up in my playing around folder and would like to add the new system to my current programming folder. I uploaded it to the BC as an addition to current program. I would like to know if I can add it through proscan with a wipe then upload, as prosan recommends! Clear as mud??? Appreciate any help!
