ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
seagravebuff60
Forensic Scanist
I seem to be having an issue with the date format in my file folders where I save recordings. When the is one digit month or day, Like January, my recording files get saved under 01 as the month and 01 as the day. So its 01-01-2019, not 1-1-2019. I went back and looked at my previous recordings and found this happened a lot. So whenever there is a one digit day or month a zero is imputed in front of the number. Is there any way to fix this. Thanks for the help
Now numbers look like this (01-01-2019)....
But I would like it changed to... 1-1-2019
ProScan
Software Provider
Ontario, Calif.
No, I don't think so. I guess you are making a suggestion. I'm not sure why you say " Is there any way to fix this." unless you are disguising a suggestion as a bug.
If you would of initially sent the suggestion via email, I would of put it on the list for later consideration. If it was a bonafide bug, I would of worked on it next after the current task.
W5RGP
Charlotte Tn
It’s not a bug and would screw up numbering if it was changed
Please leave date formats as is it atleast give an option to keep as they currently are if you plan to make this change
yorky
Hi, I noticed this came up once before for a similar issue here https://forums.radioreference.com/threads/official-software-thread.95044/post-2730778
It was mentioned it might cause issues if there was an option to set a delay in ProScan? Is there any chance there can be an option, where you can say add 2 seconds of silence to the end, waiting for the other radio party to respond into the same audio file? With what I'm listening to here they will talk for say 4 seconds, get a response a second later, and back and forward creating heaps of small files. Trying to play them back later one by one by the web interface remotely is hard, rather than the conversation being in one file.
seagravebuff60
Forensic Scanist
If you would have initially sent the suggestion via email, I would of put it on the list for later consideration. If it was a bonafide bug, I would of worked on it next after the current task.
I Presume this is meant towards me... I am Suggesting that you take a look at it for future consideration. I asked if there was any way to fix this because I was not sure if I was doing something wrong on my end... :confused:
Please leave date formats as is it at least give an option to keep as they currently are if you plan to make this change
I See what you are saying but if you set a command to get rid of the zero before the month and the date I don't see how it could screw up the numbering.
But on the other hand, I agree. Just cuz I would like it one way doesn't mean others would like it too, I Think keeping an option to keep it as IS now is an awesome idea while implementing the new suggestion.
BBang
Smiths Grove Ky.
In the last version release, I made a small modification as follows. When a user change scanner type to SDS100, the profile.cfg file is read for colors. However I didn't make it to only read if using the Sentinel Colors and not ProScan colors. I fixed it. The fix will be in the next version not released yet.
Bottom line is hit the Cancel button. If changing scanner type to SDS100 then you hit the Cancel button each time.
ProScan,
Do you have a version for Mac ios.
BBang
eaf1956
Evansville, IN
OK so I got rid of AT&T DSL (too slow and always down) Had Spectrum install and the router I now have I can't get port forwarding to work. Never had this issue with any of the other routers I've had over the years. This one is a Sagemcom Fast 5280. I believe it might be the External IP field that is causing the issue. I have tried the IP address of the router, the IP address of my internet service, the gateway IP address but nothing works. Of course the internal address I set to the IP of the computer such as 192.168.1.4 for the one I am on. The router IP is 192.168.1.1 and of course the actual IP address is something much different (Example not actual IP 73.133.56.12)
If I set DMZ (one computer only) everything works so I know the router is the issue.
Synchro39
Montreal Quebec
Try changing the port. If he doesn't know what port it's on he can't access it[/QUOTE
yes i know this trick but the problem is i want him to be able to listen to my scanner but i don't want him to be able to control my scanner i gave him my super user password and even if i changed my pass and change the port he still can control my scanner
but i think there is no way to control that thanks for your help
eaf1956
Evansville, IN
Why not just change the password. He doesn't need a password to listen
Sent from my SM-N960U using Tapatalk
Synchro39
Montreal Quebec
Restart the web server after you change it. It will log everybody off
i tried that and restrad of webserver does't log off people i also tried to close proscan completly and restart it people stay logged all the time they just have to access the page again an still have all access
eaf1956
Evansville, IN
That doesn't even sound right! If I change my password and forget and use the old one I can't even log onto my own scanner.
