ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
w2csx
Rochester,NY
Yup here we go again....oh well,thank you for your very kind support! I've never gotten this type of support before. I mean my gosh!
Instead of trying to sell your product,you have done everything but. Thanks again for your support or lack there off.
mule1075
Washington Pennsylvania
All of the questions you have asked are very vague so you get what you give. Bob's customer service is at a very high level I have been using ProScan for 12+ years and always received quality service by providing in depth answers to the questions he has asked after I had a problem. Again you get what you give.
GTR8000
NY/NJ Database Guy
BEE00
I certainly would never presume to speak for Bob, however I have a hunch that at times he might perfectly content to miss out on one or two sales if a potential customer reveals themselves to be more trouble than the $50 sale is worth. :cautious:
WX4JCW
Stow, Ohio
Picked up an SDS200 tonight, hooked up the LAN cable to the laptop and everything works quite well, streaming, file read and write, thank You Bob
ProScan
Software Provider
Ontario, Calif.
I have a question, I am running the web server at WX4JCW's SDS200 Scanner Stream
I probably won't run it permanently but just to see I can do it
so my question
1. is there a way to hide the IP addresses as shown in the screenshot
I'm not sure why you need to as anyone who can access your web server knows the URL already.
It can't be done currently however the next version will contain a file called "Web_Server_User_HTML.htm" for HTML, JavaScript/jQuery, and styles can be inserted into the file to alter the appearance of the web page.
Houdini7
Likely a delay in propagation, as they 'just' updated the ICANN record
Updated Date: 2019-04-14T11:16:54Z
Creation Date: 2005-04-09T03:12:48Z
Registry Expiry Date: 2020-04-09T03:12:48Z
ProScan
Software Provider
Ontario, Calif.
Did Proscan forget to pay for their domain name registration?
I just woke up and found out about this. I'm like not again. HostGator has got to be the worst. I checked my site billing and SSL cert paid last February and site renewal not due until next year. I was just getting ready to open a ticket when it came back up.
Jeff302
N3GJB
Wilmington, DE
I just purchased a SDS-200. I've been running a 536 with ProScan for some times with no problems other than having to reset the COM port occasionally. I was switching between the 536 and the 200 last night and version 14.8 does not fully load. I've tried a clean install, deleting the original program and gone back to version 14.6. ProScan does not recognize either the 536 or the 200. I have to go into the Task Manager to close the program. Is there something I'm no doing correctly? 536 uses COM 9, the 200 uses COM 15. Using Windows 10.
eaf1956
Evansville, IN
Com 9? Com 15? Just how are you connecting these scanners? My SDS 200 is 192.168.1.103 on one and 192.168.1.85 on the other. Haven't used Com ports since the 996 series.
eaf1956
Evansville, IN
Connect the 200 via LAN to your router and let it get it's IP then tell ProScan that IP and your Metadata and audio will be taken care of without audio wires. Be sure to set URL in both the COMM Port Menu and the audio menu.
iMONITOR
Silent Key
S.E. Michigan
Bob, when do you get time to sleep? :sleep:
WX4JCW
Stow, Ohio
i think its causing the auto update to freeze the program, or something everything was working fine then today it will run for a few seconds then completely lock up
ProScan
Software Provider
Ontario, Calif.
You're right. I didn't get any emails on the renewal but found out the emails went to my old work address which I retired from 1 1/2 years ago.
I though I changed to HostGator from GoDaddy for the domain name registration but I guess I didn't. Coding kind of makes you absent minded.
