ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
ProScan
Software Provider
Ontario, Calif.
It's showing up in the UID logging just fine. But under the recording tab it's not making a new line when the next unit keys up too fast and only logs the last UID.
The recording grid is not designed to make a new row when a different UID comes in. The Recordings are based on TGID's and conventional frequencies.
GeekNJ
trying to update to 16.2 but i keep getting error downloading saving file
Are you downloading directly from the proscan.org site and not trying to update from within the ProScan app? Download from the site, close the app, and run the installer again, installing over your current directory. This requirement was noted in the 16.2 release post.
fxdscon
¯\_(ツ)_/¯
From the Proscan post announcing the update:
Please note: To install ver. 16.2, visit the ProScan web site then download and install. Exit ProScan before installing. This is due to previous ProScan versions using SSL TLS 1.1 and not TLS 1.2 and combined with my host removing TLS 1.1. So previous versions will not download the latest version within ProScan.
GTR8000
NY/NJ Database Guy
BEE00
Norton dings 16.2 from the website as dangerous:
Dangerous? Hardly. It even states that the "file risk is medium", and WS.Reputation.1 is not a specific virus or malware threat. In fact, it's all but meaningless. Read the following:
wm8s
Houston, TX
I thought Bob might want to know.
chill30240
West Georgia
Hello, I tried to update my ProScan version and I get this:
What should I do?
cg
Connecticut
When I installed ProScan 16.2, it tried to create a new subfolder. So c:\ProScan becomes c:\ProScan\ProScan
When it asks if you want to install into the folder, simply check to see if it shows double ProScan folders. If you install it and you seem to lose all your settings, use File Explorer to go to ProScan and see if there is a new ProScan subfolder in that one.
chris
