ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
ProScan
Software Provider
Ontario, Calif.
When I installed ProScan 16.2, it tried to create a new subfolder. So c:\ProScan becomes c:\ProScan\ProScan
When it asks if you want to install into the folder, simply check to see if it shows double ProScan folders. If you install it and you seem to lose all your settings, use File Explorer to go to ProScan and see if there is a new ProScan subfolder in that one.
chris
The installer seems to work the same as always. No changes in this area. It will remember the last time ProScan was installed and will default to the same folder. For a test, you could start the installer and see if the same folder is selected.
kruser
Well Known Member
W St Louis Cnty, MO
Yep, I updated some 16 instances across two computers from Ver 16.1 to 16.2 and did not hit a single problem.
I can always tell it's installing to the correct folder as the ProScan installer will warn me that I'm installing to an existing folder and ask if I'm sure I want to install into this folder anyway. I always answer yes of course. When done with all instances, I'll start each instance and make sure it starts with the version I just installed and that it is also showing the correct scanner model and file paths. I've never had any issues.
wm8s
Houston, TX
Is anyone else running the latest version of Norton on Windows? Norton elevated the file's risk from Medium [in my previous screen shot] to "Bad" with the ominous red X:
85170
and although it doesn't get blocked on the download, Norton blocks the installer while it's running, saying that it was involved in suspicious behavior, perhaps just based on the trust rating. The "suspicious behavior" seems to be deleting the old PDF manual. Under the circumstances, I reluctantly immunized the installer's process to get 16.2 installed. But Bob still might want to see if there is something he can do about it.
kruser
Well Known Member
W St Louis Cnty, MO
A "reputation" warning should self clear after more users use the file.
Can you adjust the reputation threshold settings in Norton? I don't think Bob can do anything about this himself.
How about submitting it to Norton as a false positive for a well known program. Not sure if the home version of Norton has the ability to report things like this. The Symantec AV Enterprise editions had reporting capabilities built in which made it easy.
Reputation based warnings can be a pain in the rear as any new file can trigger the warning.
ProScan
Software Provider
Ontario, Calif.
Hello All,
I will be putting out a new release in the next few days to fix one bug that came up. The SDS200 FTP Scanner Read & FTP Scanner Write functions may show an error when trying to log in. This broke in ver. 16.2 when I added code to compare the read account & write account User Names to show a message if they are identical.
If anyone has any issues or bugs, this is the time to email them to me so I can get it in the next release.
ausscan
Thanks Bob.
I have an unrelated question to 16.2 (Which for me is working A+)
Is there a way to serve the Web Server with tags/display from another machine? I have an install where the ProScan Server instance while serving the web server and clients are connected, the CPU usage hovers around 40-50%. Typically, without the web server Proscan runs at around 13%, even with RSOIP connected. This is served up to some Android devices and one windows machine that I can't install programs on (Work). I was thinking that I may be able to relay the web server through a beefier Linux box.
ausscan
How beefy is the general consensus? It's on an i3 4130 w/ 8GB ram, I was actually looking to replace that in the near future with a NUC.
ProScan
Software Provider
Ontario, Calif.
Is that even possible? ProScan is the Web Server serving a web page so I don't know how a web page can be served on another machine.
I'm sure the CPU utilization is due to the Folders & Files Served. A lot of processing in that area. Try serving just a subdirectory or at least a lesser amount of recordings to see if the CPU utilization decreases.
ausscan
You know what - that's exactly what it was. As soon as I cleared the Serve Folder Location, usage dropped back to 13%
kirkco
Erda, Utah
Hello All,
Please check the History Logging when using option for UID Column. It seems that when the option "Display UID From Lookup File - if UID Not in Lookup File Then Display from Scanner always displays from the scanner even if there is an entry in UID lookup file.
ProScan
Software Provider
Ontario, Calif.
Can you email me so I can send you a file to see if it's fixed.
ProScan
Software Provider
Ontario, Calif.
ProScan Version 16.3 Just Released.
  • Fixed - SDS200 FTP Scanner Read & FTP Scanner Write functions may show an error when trying to log in. Broke in version 16.1.
  • Fixed - UID Lookup file wasn't working right. Broke in version 16.1.
  • Fixed - When the virtual scanner knobs are selected, and ProScan loses focus and then regains focus, the knobs are no longer selected.
ProScan supports the BCT15, BCT15X, BC250D, BC296D, BR330T, BC346XT, BC346XTC, BCD325P2, BCD396T, BCD396XT, BCD436HP, BCD536HP, BC780XLT, BC785D, BC796D, BCD996T, BCD996XT, BCD996P2, SDS100, SDS200, SDS100E, SDS200E, UBCD3600XLT, & USDS100 scanners.
ProScan is the most powerful and feature rich scanner software in the world !!!
Made in the USA
LS101
Lake Co, Ind
I just downloaded the 16.1 version a couple of days ago(Trail version), If I try and download this newer version will my trail activation still be good for the remainder of days i have or will it come up as trail has ended?
GTR8000
NY/NJ Database Guy
BEE00
You may safely update versions without affecting the length of the 30 day trial.
