ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
ProScan
Software Provider
Ontario, Calif.
As Windows 10
Are you running Windows Defender Firewall? For a test, can you turn off the Windows Defender Firewall on the computer with the web browser that can't connect to the server. If it works then you could change the "Allow an App or Feature Through Windows Defender Firewall"
ProScan
Software Provider
Ontario, Calif.
belvdr
So does the URL I provided work on the ProScan PC and not the others? How about a mobile phone on the same WiFi network?
belvdr
Works only on the Proscan PC
You have another firewall then or it is not configured correctly. Let's try disabling the Windows firewall first:
  1. Start -> Settings -> Windows Security -> Firewall & Network Protection
  2. Click Advanced settings
  3. In the newly opened window, center pane, click "Windows Defender Firewall Properties"
  4. For each profile tab (Domain, Private, and Public_, change the firewall state to "Off" then click Apply.
Retest the URL using another PC or mobile phone.
54firefighter
Schwenksville, PA
Firewall OFF
Chrome Browser Edge Browser
Proscan PC > Link Procan PC > Link
2nd PC > No Link 2nd PC > Link
Phone > No Link Phone > Link
Firewall ON
Link = Proscan Web Server Page
Coud not find the Issue with the Chrome Browser on the 2nd PC or Phone
ProScan
Software Provider
Ontario, Calif.
Firewall OFF
Firewall ON
I would verify the phone is using the WiFi and not cellular data. Also verify that the IP address and port matches.
{edit} On the phone, are you able to access or login to the router for a test? My router IP address is 192.168.1.1
ProScan
Software Provider
Ontario, Calif.
Phone on Home Network, able to login into router.
IP Address & Port entered identical on both browsers.
It looks like something on the server computer is blocking the connection. I would look at any Internet Security programs running and more then one running. Windows Security has a Domain network firewall, Private network firewall, & Public network firewall. Perhaps add ProScan to the exemption list if it's not setup to automatically prompt you to add.
{edit} Perhaps a router firewall?
belvdr
From your results, are you saying that Edge works and Chrome does not? If so, it is not the network or firewalls; I would suspect an add on is blocking it.
Chris0516
Pittsboro, North Carolina
I have, what I consider to be. A stupid ProScan programming question. I will preface it, by saying. I looked, But, I couldn't find the answer.
When starting a new system in ProScan. Is there a way(or even necessity), to do a system that is P25p1 vs P25p2?
