IndyScan
Always Connected...
Fishers, IN
Do you have a UID field on your display? I can't remember what the default layout is or if that field needs to be enabled for ProScan to log it (I'll let Bob chime in on that).
I don't believe that the Trunked Discovery display can be modified.
IndyScan
Always Connected...
Fishers, IN
You know what, I was thinking he was calling "ID Searching" Discovery & forgot there is a Trunking Discovery mode. I only played with that a bit at first & forgot about it... Sorry about that guys. I'll go back to monitor mode :)
ProScan
Software Provider
Ontario, Calif.
I am using the SDS200 and ProScan in Discovery mode. The "History Logging" and "Recorder" tabs in ProScan have rows of data; however, the "UID Logging" tab has no data displayed. Am I missing a setting to log the UIDs while in Discovery mode?
Thanks!
I will run some test and get back with you. It will be about 3 or 4 days.
deim
Universal Scanner Audio Player developer
Saint Petersburg, Russia
@ProScan Hi! i am the developer of Universal Scanner Audio Player (Universal Scanner Audio Player)
I'd like to discuss with you possibility to add some additional info in mp3 files. And adding ProScan mp3 files to the supported file types of the Universal Scanner Audio Player.
I think it will add conveniences to your customers to search and sort recorded audio files.
PS I've been approached several of ProScan users with this request.
gdsteele
I have searched and searched, but I can't find the answer. I know it has been answered. But....
When I set my SDS200 up the way I want with the Favorites set, the Systems set, the Departments set, etc, how do I save this in ProScan? It seems when after I do an edit and a download, it's not the way I had it. Do I need to do a read from the scanner before I modify the settings? Is there anywhere in ProScan that shows the state of the Favorites, Systems, etc that they will be upon a write to the scanner?
If you don't believe how hard this answer is to find, try searching "Favorites" in the Scanning Software forum....
Thanks!
ProScan
Software Provider
Ontario, Calif.
Thanks!
After you make changes in the Favorites Editor, you want to do a Scanner Write (or FTP Scanner Write). Not a Read.
ProScan
Software Provider
Ontario, Calif.
Send me an email please.
ProScan
Software Provider
Ontario, Calif.
Thanks!
I looked at this. It doesn't appear possible to log the UID. The UID doesn't appear in the received data from the scanner (protocol) nor on the display.
jonwienke
More Info Coming Soon!
VA
If you're running ProScan, there's little reason to use discovery mode. Just hold on the system in ID search mode, and log and record. If needed, avoid known talkgroups. You'll get more and better data than by using discovery mode.
Thanks for the information, Jon. I will give it a try.
ProScan
Software Provider
Ontario, Calif.
ProScan Version 17.0 Just Released!
  • Fixed - Importing from the Sentinel Database wasn't showing all the parameters correctly.
  • Fixed - SDSx00 scanners - Wasn't logging the UIDs on conventional P25 systems. Display needs to be in Detail mode.
  • Added - Logging & Recording grids - Right click copies the selected rows to the Win Clipboard.
  • Added - Web Server - Server Mute button on the web page to indicate and control the server side mute icon.
  • Changed - Reset Hit Counter button now resets all the grid entries and not just the new entries.
  • Improved - Sessions Manager all around.
ProScan supports the BCT15, BCT15X, BC250D, BC296D, BR330T, BC346XT, BC346XTC, BCD325P2, BCD396T, BCD396XT, BCD436HP, BCD536HP, BC780XLT, BC785D, BC796D, BCD996T, BCD996XT, BCD996P2, SDS100, SDS200, SDS100E, SDS200E, UBCD3600XLT, & USDS100 scanners.
ProScan is the most powerful and feature rich scanner software in the world !!!
Made in the USA
Chris0516
Pittsboro, North Carolina
Made in the USA
Bob, I always enjoy. Seeing what new things you have added/fixed!!
:) (y)
JASII
Memory Capacity
I checked the History Log today and found this. I Assume the CC15/CAP entries are erroneous. Does this indicated that this is an Idas trunked system, since no RAN Code was logged? Could it be a single channel Idas or could there be other frequencies, but I simply didn't catch them active? It looks like just Talkgroup 172 was in use by Unit IDs 17001, 17002 and 17009. That is must be a very quiet system.
172464.075000/2CC 15-9717009NFM300:00:0201/04/21 10:17:1101/04/21 10:17:13Action Radio - Action Radio West Saint Paul - 464.075000MHzConventionalCAP
172464.075000CC 15-9817002NFM200:00:0201/04/21 09:18:5701/04/21 09:18:59Action Radio - Action Radio West Saint Paul - 464.075000MHzConventionalCAP
172464.075000A 0-8817002NFM400:00:0201/04/21 10:17:1701/04/21 10:17:19Action Radio - Action Radio West Saint Paul - 464.075000MHzConventionalNX4
172464.075000A 0-8817001NFM100:00:0201/04/21 09:18:3701/04/21 09:18:39Action Radio - Action Radio West Saint Paul - 464.075000MHzConventionalIDS
