ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
Chris0516
Pittsboro, North Carolina
Below is a screenshot of my problem. Scanner is recording pefectly for 2 towns, Newark & Verona. But for whatever reason North Caldwell is grayed out every morning when I check. I'm not around when that town is transmitting so I'm not sure what is coming out of the speaker. I can't see anything that would cause this.
When you look every day. Has the data for Newark, and Verona changed? Or stayed the same? Like nothing happened.
gootch
Sun Prairie Wisconsin
looking to have Talk Groups all go to the same line on the recorder page. As you can see from the screenshot my recordings populate by talk group and tower site. is there a option to have all the activity on a system all go to the same talk group line in the recorder window. What I am trying to do is be able to play back sequentially for all sites by talk group instead of have separate lines for the site which breaks up the sequence of a particular talk group. Hope that makes some sense. Thanks.
Chris0516
Bob can correct me. If I am wrong. But the only way I can think of. Is to Lockout all but one 'system'. So you only see the TG's in one System, when you click on 'History Logging'.
ProScan
Software Provider
Ontario, Calif.
There's no option for that. The recorder is based on TGIDs and conv. frequencies. To play back sequentially, try sorting the System/Site column (primary sort) and the TGID column (secondary sort) then they should be in order you want then select the recordings in the same site then play them.
ProScan
Software Provider
Ontario, Calif.
How do I set the Tone on p25 systems, in Proscan? I can't find the answer.
Assuming you're using a BCDx36HP or SDSx00 scanner.
On a conventional P25 system, it's done at the channel level. Click the Audio Option button then change the Audio Type to Digital then change the Digital Option to the NAC code.
The procedure for DMA type of scanners is almost the same.
Chris0516
I have a 325p2. I did a conventional test system, and found it. But, Thank you, for the added details. (y)
Moose
New Jersey
Filename probably longer then 260 characters.
That was the problem. Working good now. I do have another unusual situation if I have your attention? What would cause the audio to not be in sync with the display after being left alone overnight? Audio lags about 3-5 seconds. I restart Proscan and it returns to normal. Thanks
IQ_imbalance
Thinking about repurposing an old (circa 2006) iMac to run Windows 7 and ProScan. Before i go down the rabbit hole of installing bootcamp etc., is the current version of ProScan compatible with 32-bit Win7?
ProScan
Software Provider
Ontario, Calif.
Yes. Starting with the next version, will run only on Win 7 SP1 and above.
JASII
Silent Key
I was sorting through the History Log and noticed the entries below. I assume that the first one is an error, since it was only logged once.
(I think with regular DMR (not CAP+, CON+, DT3 or XPT) a specific Talkgroup that will work on one Frequency and Time Slot, right?)
11 463.475000/1 CC 7 -118 349 NFM 1 00:00:08 01/17/21 20:07:59 01/17/21 20:08:08 DMR
11 463.475000/2 CC 7 -118 358 NFM 75 00:09:59 01/13/21 13:05:11 01/18/21 17:04:21 DMR
