ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
webstar22
RenfrewCountyScanner.com
Ontario, Canada
I emailed this as well. I currently push out the RID's on my feed and I thought it would be cool to be able to name them too.
Top is a Radio ID I entered and it shows up on the scanner display as 2OPS07 Dispatch but does not get sent in the Metadata to my stream. But the buttom which is a radio ID the scanner is picking up does get sent along because I guess Proscan sees the UID:i1313 UID:i gets removed if you put names to radio ID’s.
Anyway to make this work? Even if I had to put a – or something in front of the names of the radios so it gets picked up.
MDL,BCD996XT
STS,011000, ¬¬ ,,Fleetnet ,,2OPS07 ,,2OPS07 Dispatch ,,S0:-234*-**-0 ,,GRP1--4------ ,,1,0,0,0,0,0,5,GREEN,1
GLG,8960,NFM,0,0,Fleetnet,OPP,2OPS07,1,0,NONE,NONE,NONE
VOL,10
SQL,1
PWR,428,01429500
MDL,BCD996XT
STS,011000, ¬¬ ,,Fleetnet ,,2OPS07 ,,UID:i1313 ,,S0:-234*-**-0 ,,GRP1--4------ ,,1,0,0,0,0,0,5,GREEN,1
VOL,10
SQL,1
PWR,441,01414350
ProScan
Software Provider
Ontario, Calif.
ProScan 4.6
ProScan 4.6 just released 10/12/11
  • Added - DMA scanner database sort by frequencies and talk group IDs.
  • Added - Logging Options - "Use Tone For Matching And Hits".
  • Added - Recorder Options - "Use Tone For Matching".
  • Added - Logging and Recorder Options - "Delete < 2 Seconds Log Entries".
  • Added - Recorder VOX Mode - Now shows the frequencies, talk group id's, and text tags.
  • Changed - Recorder - File duplicates renamed xyz #1.wav, xyz #2.wav, etc...
  • Fixed - Non DMA Scanners - Metadata custom formatter %L1 wasn't working.
  • Fixed - Logging - Tone was showing in the next entry.
  • Fixed - DMA Scanners - Downloading the database locations info wasn't working.
  • Many many more small improvements.
ProScan is available at http://www.proscan.org
ProScan supports the BCD996XT, BCD396XT, BCT15X, BC346XT, BCD996T, BCD396T, BCT15, BR330T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D scanners.
ProScan is the most powerful and feature rich scanning software in this world.
ProScan
Software Provider
Ontario, Calif.
It's kind of complicated but I will try to keep it simple and clear. These options are for the the logging and recording grids. It's for those that have the option "Each Transmission New Row" turned off. This option will look-up existing entries with new transmissions based on frequency and if a match is found then will update the existing entry.
Now on tones. Tones can be problematic to logging and recordings as the tone data may arrive late(after the beginning of the transmission) to the software depending on the way the scanner is setup. When the scanner is in scan mode and the tones set at the channel level then the tone data will arrive instantly. When the scanner is searching for tones, then they will arrive late. For those that want the frequency AND TONE data to match existing entries then the option "Use Tone For Matching And Hits" is turned on. The scanner needs to be in scan mode and the tones set at the channel level so the tone data will arrive instantly.
The Hits column in the logging will increment based on frequency. If the user want to increment based on frequency AND TONE then "Use Tone For Matching And Hits" should be turned on. The scanner needs to be in scan mode and the tones set at the channel level so the tone data will arrive instantly.
ProScan
Software Provider
Ontario, Calif.
ProScan 4.7
Small update but important.
ProScan Version 4.7
  • Added - RadioReference Database Import - Nationwide Systems.
  • Fixed - Date region setting set to Day/Month/Year would cause an error. Broke in 4.5.
milan
Proscan 4.48
I am using the latest version of Proscan on an XP Pro machine connected to a Bearcat 780xlt.
I have tried the new option under "Broadcast lockout" and entered in a frequency, but it still seems to broadcast the frequencys on my Radiorefernce stream.
For example if I would like to lockout 156.8000
I tried entering 156.8000 #
and also # 156.8000
but it still broadcasts the frequency.
Am I missing something or doing something incorrect?
Milan
webstar22
Ontario, Canada
and also # 156.8000
Milan
I reported the same issues and never got a response.
rmosier
Mt. Olive,NJ
I reported the same issue, then it occured to me. The way the information is writen in the notepad file is confusing. "Anything following the # sign is ignored". Yes....Ignored completly. As though it were a comment line. Just enter the frequencies you want not to be broadcast WITHOUT the # sign and it works perfectly.
Here's my file:
BROADCAST LOCKOUT FILE (SOURCE CLIENT & WEB SERVER)
Add frequencies and talk group ID's not to broadcast.
# Anything after the pound sign(#) is ignored.
# EXAMPLES:
# 484.5875
# 4208
# 4208 # Ontario PD Pri
# 0-01-002 # LTR Talk Group ID
# 11Fh # Uniden XT Models Talk Group ID Hex Format
000.0000 # Example of a frequency
00000 # Example of a talk group ID
16592
54864
59312
36272
36304
36336
36368
417.4000
417.4500
417.5000
417.5500
418.0500
418.6250
418.6750
418.8750
418.9500
418.9750
167.1500
167.2625
167.2650
167.3625
167.4375
167.4875
167.5625
168.1000
168.2250
168.3000
168.6500
168.8250
168.9750
169.6375
169.8875
169.9700
169.9750
170.3750
170.4250
170.4500
170.6250
170.8125
170.8250
170.8375
170.9000
171.4375
172.1875
172.2875
172.4000
172.4250
172.4750
172.5250
172.6000
173.6625
173.8125
173.9375
Ray.
P.S. BOB - Love these updates. Now I can once again supply my feed to RR without having to give up my FBI monitoring.
ProScan
Software Provider
Ontario, Calif.
Good point. I try to make it less confusing as possible.
Do you have any suggestion on how it can be re-written?
webstar22
Ontario, Canada
I always assumed if it was put into place the no broadcast would be a checkbox the same as a record flag. Check the boxes you would either broadcast or not broadcast.
How come you went with the text file?
ProScan
Software Provider
Ontario, Calif.
Seriously? I could see the complaints poring in. The broadcast lockout should not be dependent on a database open or closed and not the record flag. More versatility and less confusing. Clicking the Broadcast L/O button brings up the file. The file contents are in memory regardless of if the file was modified. I've seen database files with thousands of channels. Can you imagine searching thousands of rows every 200 milliseconds. There would be performance issues i'm sure.
cg
Connecticut
I want to continue to have my recording filenames to include unit IDs. I have used it in the past, is it possible it was removed in the last two versions? My Custom Filename Format is %DT - %FT - %U although I have tried several other ways. If I use just %U, the filename is
No Format Specified.wav
Using 996XT remotely with Proscan V4.7 on both computers. I can see the UIDs and they are logging fine.
chris
ProScan
Software Provider
Ontario, Calif.
chris
I will look at this before the next release.
ProScan
Software Provider
Ontario, Calif.
ProScan 4.8 Is Out
ProScan Version 4.8
  • Added - Google Maps and Lookup with many options. Accessed in the Tools menu or the database Location Lookup.
  • Added - FCC Callsign Lookup on the RadioReference site. Accessed in the Tools menu.
  • Added - Audio scopes. Double click to change modes.
  • Changed - Reworked the tone logging and recordings with an option "Use Tone For Frequency/Tone Matching...".
  • Changed - Web Server password protect folders and file will now not allow the media player to play streaming audio.
  • Fixed - Non DMA Database - Importing tone from history grid to database wasn't working.
ProScan is available at ProScan
mrkelso
NNJ
ProScan Version 4.8
Up and running, i will check it all out later today.
WB2UZR
Melbourne, Florida
Recorder on after upgrade
Not sure if this happened to anyone else, but FYI, the recorder was toggled on after upgrading to 4.8, and I had to go in and turn it off manually. Noticed it on both scanner setups, so might be worth taking a look at.
Scott/WB2UZR
