ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
ProScan
Software Provider
Ontario, Calif.
Folks,
Each upgrade I hear from at least 7 or 8 users (super small percentage of users) that this or that stopped working. In all cases lately with one exception, the problems have been external to ProScan. I guess it's easier to put blame on the software then doing any troubleshooting and checking the setup for the very few. The most common fixes I heard about are: 1) ProScan was installed in a different folder then the original causing the configuration to be slightly different. 2) Power cycling the scanner. 3) Internet Security/Antivirus software needing an exemption. 4) Power cycling the router. 5) Rebooting the computer. I just want to get this out because I heard it once on this upgrade already and the next time, I can refer him or her to this. Now I said this, the next bug report will actually be a ProScan problem.
The one exception is a recent IOS upgrade caused the iPhone browsers virtual scanner buttons to break.
Synchro39
Montreal Quebec
updated this morning to 18.2 and here is my display i rebooted the system still the same i have another instance of proscan running on 18.0 and this one is ok
any idea what i can do to get back full display
Synchro39
Montreal Quebec
I'll look at it before the next release.
{edit} The Web Server always worked this way.
always used ProScan minimized and sometime this problem was there but my easy fix was to change the view option and display on the server side was back to normal even when ProScan is minimized but this time nothing worked except unminimized
but it's ok for me now i have a fix
Thanks Bob for all your hard work
ProScan
Software Provider
Ontario, Calif.
No changes in that area in a long time. Try reverting back to the version that worked before and see what happens.
ProScan
Software Provider
Ontario, Calif.
Also it's difficult to determine the exact problem when a bug is reported via message boards. On emails, I may ask a few questions or more and send out test files until fixed. Basically, when bug reports come in via email initially, they go to the top of the list. On bug reports via the web, all I can offer is I'll look at it before the next version.
Jeta1
Question, does this new release affect the .css or webserver.html file? I currently use the black .css file that was supplied on this site.
Thanks for the continual improvement!
Jeta1
ProScan
Software Provider
Ontario, Calif.
Jeta1
Yes on the javascript and no on the css. Is something a different color or something?
tweiss3
Is it time for Coffee?
Ohio
The only odd thing I had happen lately was when I connected the SDS100 to a third instance of Proscan for logging, sdrTrunk threw a fit and refused to decode. No issues with the two other instances with BCT15x. I think it was a computer hardware issue and nothing related to Proscan, since it didn't start until the connection to the scanner happened.
ProScan
Software Provider
Ontario, Calif.
Try power cycling the scanner. If that doesn't solve it then check the Device Manager and see if the driver is working. Wiggle the cable.
