ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
N2ICV
Gloucester County FM29in
Sorting the system-group-channel column will show in alphabetical order. Click on the column header to sort.
I know I can do it that way ! Thats why I asked ...
"show the hits by alpha tags (system-group-channel) in alphabetical order """automatically"""" !
So I DONT have to "Click on the column header to sort".
ProScan
Software Provider
Ontario, Calif.
SpringHill
Spring Hill. TN
i think proscan version 4.9 has a timer bug. timer being the trial timer. i downloaded the trial of this software about four days ago and it always pops up to let me know that it is a trial but the remaining time on the trial remains 30 days. thought you should know! ill be honest about it though and quit using or buy the software after my thirty days has passed because i respect your work and im thankful for your time and dedication to make this software! Thanks! :)
eaf1956
Evansville, IN
hmmm
I just installed that version. :) Never would have seen that bug though cause mine is registered. Did find a small bug in another APP which I reported to the aurhor. This helps them to make the software better in my opinion.
slylingus
Stream Re-naming in source client
Howdy been streaming on one stream with ProScan source client noticed in version 4.9 the stream rename for RR streams.
What field renames the stream?
stream discription?
stream name?
Is there a delay?
Thanks Cheers Sly
ProScan
Software Provider
Ontario, Calif.
stream discription?
stream name?
Is there a delay?
Thanks Cheers Sly
It shouldn't be renamed. Where do you see it and what is it renamed to?
No audio delay at the source. The IceCast server and the media player produces a small amount of delay intentional.
slylingus
MM I'm just a bit confused as what you mean by
Changed - Source Client - Stream to Radio Reference now can change the stream name.
Does this rename the RR stream at RR or just in ProScan?
Also ProScans been locking up on my XP system Unhandled Exception Report attached FYI
Thanks Cheers
  • UnhandledExceptionLog.txt
ProScan
Software Provider
Ontario, Calif.
Thanks Cheers
The stream name was hard coded "PS". Now with 4.9, it can be changed. Depending on the media player, it may show. WinAmp will show the stream name in parentheses along in the metadata area along with the metadata. Nothing is changed on RR.
ProScan
Software Provider
Ontario, Calif.
Thanks Cheers
The stream name was hard coded "PS". Now with 4.9, it can be changed. Depending on the media player, it may show. WinAmp will show the stream name in parentheses in the metadata area along with the metadata and the File --> View file info menu. Nothing is renamed on RR and it's not possible anyways..
slylingus
Thanks for that, I have just started broadcasting meta data and have rearranged my databases.
Outstanding program have just started to stream both streams with ProScan in the past the RR dropouts leadme to believe that scanner cast was preferd.
In the end RR kick you once a day that's great in my opp you get a much more stable stream.
Long time ProScan user.
Cheers Sly
ShawnInPaso
Just a word of thanks for the recent upgrades to Proscan. I had been running v4.7 until I recently downloaded v4.9. The new features are great; love the big scope too!
webstar22
RenfrewCountyScanner.com
Ontario, Canada
Bob, how long is a license good for? I just bought a new motherboard & CPU, and my times to install has been exceeded again.I install the Windows betas & etc. I hate to keep asking.
You have to unregister the software on your current hardware, install the new hardware and re-register and it will work. I ran into the same issues before.
ProScan
Software Provider
Ontario, Calif.
Licenses are good indefinite. If just changing hardware, ProScan will work in the activation mode afterwards. If reformatting the HD, then the the activation has to be removed first and re-activated afterwards.
Email me on any license problems.
ProScan
Software Provider
Ontario, Calif.
ProScan Version 5.0
ProScan Version 5.0
  • Added - Recording Options - Recording prepend buffer from .5 to 5 seconds insures won't miss the beginning of audio.
  • Added - Logging Options - "New Entries Auto Sort".
  • Added - Recording Options - "New Entries Auto Sort".
  • Added - Startup Options - "Remember Last Sort Order Logging & Recording Grids".
  • Changed - Options - Rearranged options in tabs accordingly to catagory.
  • Fixed - Recorder - When using a date specifier for the folder, a new recording wasn't created for a new date.
  • Fixed - Recorder - When playback a recording and recorder attemps to record to that recording, the recorder would turn off.
  • Many more small improvements.
At this time, there are no known bugs or issues.
ProScan supports the BCD996XT, BCD396XT, BCT15X, BC346XT, BCD996T, BCD396T, BCT15, BR330T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D scanners.
ProScan is the most powerful and feature rich scanning software in this world.
