ProScan
Software Provider
Ontario, Calif.
ProScan Version 1.7 Build 2 includes the RadioReference Imports feature, improved Scanner Over IP, and bug fixes.
Supported scanners are the BCD996T, BC796D, BC785D, BC780XLT, BC296D, and the BC250D.
I'm thriving to make this the best Computer Aided Scanning program and suggestions are very much appreciated.
http://www.proscan.org/index.htm
Bob
fxdscon
¯\_(ツ)_/¯
I got the version update notification when opening Proscan, but the downloaded .zip file appears to be empty.
ezdropper
Maryland
I have the scanner control box but there's nothing in it, just a grey box. Is there a way to turn ir off or hide it?
marcotor
I ♥ÆS Ø
Sunny SoCal
What Windows version running? I can't duplicate that. I'll keep a watch on this.
Windows 10 Pro 22H2 on a HP 400 (mini) i3 with 8GB RAM. Was comtemplating I haven't installed clean in a long, long time. Created all new directories for the 996XT and P2, and that solved the issue. If I had to wager a WAG there was something in the legacy directories causing the weirdness.
ProScan
Software Provider
Ontario, Calif.
I have the same display with all the grey. Using windows 10 home ver 22H2 OS build 19045.2193
I have the gray box also. It says "Scanner Ctrl" at top, but nothing else. Win 11 pro. And this is happening for SDS200, SDS100 and BCD536HP for me. Three installs on same Win 11 pc.
Send me an email so I can send test files until fixed.
I'm not sure what you mean by "legacy directories" No directories have been changed but I was hoping an email with your config file attached so I could take a systematic approach to fixing this bug. Too late now as you found a work around. My guess is it was something in the config causing this.
ProScan
Software Provider
Ontario, Calif.
ProScan Version 20.1.0 Just Released!
  • Fixed - Scanner Control box wasn't showing correctly.
ProScan Website
ProScan is the most powerful and feature rich scanner software in the world !!!
Made in the USA
dave3825
Suffolk County NY
I am running 2 instances of Proscan, Sds200 & Bcd436hp. I just updated the first which was the original install, and would like to know the process for updating the second instance. Do I just copy proscan.exe into the second folder?
ProScan
Software Provider
Ontario, Calif.
It's best to download and run the setup file. You can copy the contents of one folder to another but then you will get all the logging files pertaining to the other instance.
GTR8000
NY/NJ Database Guy
BEE00
99% of the time all you need to do is copy ProScan.exe into the other program file directories. Occasionally, a dll or other file is updated, so you need to be aware of that. The last change of that nature was to ProScan1.dll around June 30th, so it's always best to check the modified dates of those types of files when copying the exe over.
Reconrider
Inside the Galaxy
Radio Galaxy
Anyone else notice the "Fill Down" is not doing everything you highlighted?
I can have 5 highlighted and it will only 'fill' 1 at a time
dave3825
Suffolk County NY
Thanks guys. I actually looked at all the dll files yesterday and saw they all had the same date and figured it was just the exe.
During the INSTALL I change the line in the installer.
EXAMPLE
C:/Proscan1
C:/Proscan2
C:/Proscan3
I think I am going to lay mine out like that. Pc only has one line in and I still have a Br330T I would like to get hooked up once I figure out how to get additional audio in to this pc.
Reconrider
Inside the Galaxy
Radio Galaxy
What type of scanner?
What is the column name?
Are the cells selected in the column indicated by the blue color highlight?
Sds100
Yes. I selected the “avoid” cell in a trunk system
I selected the first one to be checked then highlighted ~5 below that and clicked “fill down”.
Only 1 would be filled after clicking fill down
